Are Chinese 6N2 the same as Russian 6N2P?
Old 29th January 2010, 12:13 AM   #1
homemade is offline homemade  United States
Default Are Chinese 6N2 the same as Russian 6N2P?
I did search , but still unsure if the 6N2 is equal to the Russian 6N2P. I'm looking for alternatives to the Chinese 6N2 , so ultimately , I need a tube that will work .
Old 29th January 2010, 12:25 AM   #2
Eli Duttman is offline Eli Duttman  United States
AFAIK, it is. Look at the data sheet. Notice the Hanji character directly adjacent to the 6N2. I can't decipher such things, but a "P" sound would not be surprising.
While the type pins out like a 6922, the triodes are the "same" as those in a 12AX7/ECC83. If the unit you are working on is point to point wired, connecting pins 4 & 5 to a heater power lead and pin 9 to the 2nd heater power lead is all that's needed to use the 'X7. More than 1 decent and affordable 'X7 variant is available.
Eli D.
Old 29th January 2010, 12:56 AM   #3
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Here is a datasheets of Russian 6N2P.
http://klausmobile.narod.ru/td/data/_6n2p.GIF
It is identical to Chinese 6N2 as shown below.
http://www.mif.pg.gda.pl/homepages/f.../095/6/6N2.pdf
Both of them describe Mu is 97.5.
Old 29th January 2010, 12:57 AM   #4
Thank you for the data sheet. The 'pre amp' board I'm using is printed circuit. One of these pre-made Chinese SRPP on ebay. I'm using it to amplify a resistor i/v mod in a tda1541 player. One of the tubes was damaged in shipping , so I'm just looking for a tube(s) that will work.
Old 29th January 2010, 01:11 AM   #5
When I went to China as a business trip, I bought a PCB which is a raw
PCB without components assembled for DIY purpose. I analyzed the
circuit schematic and published it in my blog below (sorry written in Japanese,
but you can see photograph).
http://ja1cty.at.webry.info/200912/article_3.html
The schematic uses 6N3 whose Mu is 36. Therefore the amp gain of this
SRPP is 15.5 which is calculated by a circuit simulation.
Old 29th January 2010, 01:29 AM   #6
上海で真空管ラインアンプのPCB買いました JA2DHC/JA1CTYのブログ/ウェブリブログ
Very good to know
I purchased 2 of these boards; one uses the 6N2 , the other uses 6N1. Both 'SSRP' config. Seems the 6N2 has a mu of 100 , so I guess the srpp circuit gives a gain of about 50(?). The 6N1 board has lower gain , as expected , with a mu of 30. The 6N2 circuit allows use of a smaller i/v resistor , so perhaps , less distortion(in theory). I'll try some 6N2P-EV tubes in the 6N2 board.
Old 29th January 2010, 05:27 AM   #7
sulcorebutia is offline sulcorebutia  Hong Kong
The Hanji character directly adjacent to the 6N2 means "type". The whole sentence that line is "6N3 type Dual Triodes".
Chinese 6n2= Russian 6N2P (6h2n in cyrillic?)
Eli is right, there seems to be no Western equivalent. It stuffs two 12ax7 alike triodes with 6922 pin out.
Old 29th January 2010, 07:42 AM   #8
typo mistake: The whole sentence in that line read as "6N2 type Dual Triodes".
Old 29th January 2010, 09:42 AM   #9
Arnulf is offline Arnulf  Europe
With your question answered already, I was wondering what the point of using ECC83-like tube in SRPP would be ? If one needs extra drive, a follower (using an '81 or '82) will do better. If extra drive is not needed, then it's a waste of 1/2 of tube.
Old 29th January 2010, 12:21 PM   #10
I am quite certain that your assessment is correct. We'll need to blame Lampizator for this , as he is enthusiastic about this type(SRPP). I know little about tube circuits. These boards became available on ebay pretty cheap. And I like the horizontal tube layout , as they fit nicely in most cd players(Philips 1541 types at least). They also have the necessary gain for use with resistor i/v low output.
Are Chinese 6N2 the same as Russian 6N2P?Hide this!Advertise here!
6N2, 6N6, 6N11 - Please help a beginner! (long) horace Tubes / Valves 41 27th November 2013 07:19 PM
Selling 6n2p lot of 100+ UssrTradeCom Vendor's Bazaar 0 5th January 2010 06:43 PM
6N2 swap tvrgeek Tubes / Valves 3 14th December 2009 07:22 AM
Copyright ©1999-2017 diyAudio
