diyAudio Sponsor
Old 28th January 2010, 12:57 PM   #1
Default Old electrolytic caps ok? MOSCODE 600
My Moscode 600 is almost 25 years old. It has been played approximately 2 times a week since it was new (each time ~2 hours). It had several of NYAL mods years ago. It was also not played at all for about 3 years when I got into amateur telescope making.
The electrolytic caps on this thing are huge!
I've read that they can blow up.
The caps look fine, and sounds fine. The amp does not sound nearly as good as the simple se's that I've made.
Should I change the electrolytic caps for safety?
Should I change them for better sonics?
Anyone have a schematic for this beast
Paul
Old 28th January 2010, 03:13 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Al Electrolytics dry out over time and use. The general guideline I've seen is 10 years of use. Being that it is 25 years old, I'd change them if it were mine.
Without a schematic it is not possible to make recommendations other than original equivalent replacement with either Al Electrolytics of the same or greater voltage rating, or Motor Run caps as an upgrade. Again, same uF value with equal or greater voltage rating.
Old 28th January 2010, 03:26 PM   #3
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
25 years is getting up there. It certainly couldn't hurt the sound to replace them. Just depends if the cost will be worth it to you. You may find that it may never sounds as good as the SSE that you already have.
Funny story...my parents have a Kenwood receiver that's about 25 years old as well. Nothing special, just your run-of-the-mill surround sound receiver with lots of buttons and a fancy VFD. The thing has a 60 Hz hum that's been getting worse as the years go on. It sounds worse than my old organ amp. Just makes me laugh to think that it probably needs to be recapped and the cost of the caps is probably several times that of a new receiver.
Old 28th January 2010, 04:17 PM   #4
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Re-capping is a very easy job
I'd just find direct replacements from your favorite source, if you want to keep the amp.
Jim J.
Old 28th January 2010, 06:36 PM   #5
vaughn is offline vaughn  United States
I had a 600 that I replaced the caps on, a relatively easy job to do. A very powerful and (to some still) desirable amp. I would say it is definitely worth doing...
Old 29th January 2010, 12:56 AM   #6
AVWERK is offline AVWERK  United States
Don't use NOS caps although Ive done it myself. Bite the bullet and buy new ones if you want the best and tightest bass response. NOS electrolytic's suffer in that area
David
Old 29th January 2010, 11:18 PM   #7
We're just talking the two big can capacitors right.
The amp has about 20 MKP's as well.
Based on the expected life of one of these I should have many years of life on those right.
Paul
paralleling film caps with electrolytic caps jarthel Power Supplies 381 10th March 2012 08:13 AM
Moscode 600 hum/turn off thump MattV Tubes / Valves 17 9th July 2011 09:13 AM
Moscode 600 dracoskeeper Tubes / Valves 1 29th November 2008 11:04 PM
Does someone know these electrolytic caps? 12 Cents Parts 4 25th November 2005 09:26 AM
Electrolytic Caps MRehorst Swap Meet 5 12th December 2002 03:45 PM
Page generated in 0.08406 seconds (77.32% PHP - 22.68% MySQL) with 10 queries
