diyAudio Sponsor
Old 28th January 2010, 07:05 AM   #1
dsavitsk's Avatar
Default Transformer Flux Band Tips and Tricks?
Can anyone offer any tips on how to add a flux band to a transformer? Do I just wrap some copper, or does it need to be electrically connected in some specific way? I am getting a tiny tiny bit of induced hum from the PT to the OPT and am looking to try this as a way to quiet things. Also, is this better to do on power transformers, or outputs, or both?
http://www.ecpaudio.com
Old 28th January 2010, 01:14 PM   #2
the simple way is to turn the direction of both transformers, there will have a point of the best
Tony Ma
Old 28th January 2010, 03:37 PM   #3
tvrgeek is offline tvrgeek  United States
Or space, or , if the chassis is steel, raise them on some non-ferrous hardware like brass.
Old 28th January 2010, 04:17 PM   #4
kevinkr's Avatar
Use a copper strip that almost completely covers the bobbin window oriented so that it parallels the windings, pass it over the outside of the core - not around the bobbin otherwise this will look like a shorted turn. Should be snug against the outside of the windings and the core - solder where the ends meet. Check primary excitation current (no secondary windings connected) before and after (if the band is acting like a shorted turn the current will be very high relative to before) check for excessive heating.
I would use it only on the power transformer.
FWIW I'm quite sure Doug has taken all of the usual precautions, hence his question about the flux band.
www.kta-hifi.net
Breadboarding/Prototyping - How to and Tips/Tricks Steven-H Tubes / Valves 60 26th August 2010 02:37 PM
New tricks for an old dog greenie512 Full Range 2 12th January 2007 10:58 AM
Couple of tips/tricks peace brainerd Everything Else 0 10th April 2006 03:57 PM
Page generated in 0.06769 seconds (74.27% PHP - 25.73% MySQL) with 10 queries
