diyAudio Sponsor
Old 27th January 2010, 08:10 AM   #1
Default current driver tube amplifier
Ultrasound Otello this Italian amp, ten PL519 tubes per channel, not a wattage amplifier but a current/amperage amplifier.
The revolutionary Ultrasound amplifiers
Does anyone know how it works or circuit architecture?
thank you!!!
Old 27th January 2010, 10:33 AM   #2
SY's Avatar
"practically everything has been built ad hoc by three engineers"
Unintentionally funny.
In any case, one can make an educated guess- they're running the tubes in pentode mode and attaching the speaker at the plates.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th January 2010, 11:48 AM   #3
Loren42 is offline Loren42  United States
"Three engineers who have worked for almost 5 years on it:"
I hope that was not full-time or 15 man-years! They will never recoup their investment.
Old 27th January 2010, 01:02 PM   #4
godfrey is online now godfrey  South Africa
Don't know what their circuits looks like but...
Current drive does give lower distortion and less power compression.
Frequency response tends to be a problem though.
Here's a paper Mills and Hawksford wrote about it 20 years ago:
http://www.essex.ac.uk/csee/research...nt%20drive.pdf
and here's their ideas for circuit architecture:
http://www.essex.ac.uk/csee/research...0amplifier.pdf
More Hawksford papers on various subjects here:
Malcolm Hawksford - Publications
p.s. Here's a book: The Secret of Tube Amplifiers Revealed - and much more!
Old 28th January 2010, 10:41 AM   #5
thank you! godfrey
Old 28th January 2010, 11:07 AM   #6
Smile Inconceivable !!! Output Impedance 200 Kohm ,Peak current 8 A
thank you ! godfrey
Simple 200 watt complimentary FET amplifier (possibly tube driver?) deltavektor Solid State 6 15th May 2011 07:15 AM
EL84 driver tube, with less than 5mA current then_dude Tubes / Valves 21 4th December 2007 07:44 PM
Current rating and tube current draw cbutterworth Tubes / Valves 1 13th October 2006 04:42 AM
Tube driver for a SS power amplifier gianmaria Tubes / Valves 21 6th September 2005 12:09 PM
Page generated in 0.08424 seconds (75.32% PHP - 24.68% MySQL) with 10 queries
