| diyAudio Sponsor | ||
ok so i just found this decware zkit4 or stereo gainstage kit. has any one here built it? also what voltage does it run at because it does not say on their site and i would rather pay les than $50 for the psu.
http://www.decware.com/newsite/zkit4.htm Last edited by Bob_345; 27th January 2010 at 12:59 AM. |
#2 |
Hi!
+U must= 250-280 v. You can use main trany with secondary U=220-230v, 4 pcs.fast rect. diodes BYV26E, electr. caps 2 pcs 220-330uF/350-450v and little chock 20-30ma. /For good sound You'd use tube mode with Ia=apr.5-7 ma, but You must change plate res. 47kohm to 20-25 kohm and cathode res 1 kohm to 500-600 ohm/. In this schematic Ia=apr. 1 ma, it's very small for this tube. It will sound better with more Ia !! This tube has very good sound! Why don't You make preamplfier Yourself? Good luck! Last edited by azazello; 27th January 2010 at 08:31 AM. |
#3 | |
Aikido 9-Pin Stereo PCB |
#4 |
Bob,
Go back to the DECWARE site and read the write up on the modded Tascam CDP. IIRC, Steve Deckert "starves" the 12AU7 heater to obtain a particular voice. The bare PCB stuffed with parts you source yourself may be the best option. Frankly, I'm not a fan of 12AU7 voltage gain blocks. Put a 6FQ7 or 6GU7 in the socket and better linearity is your reward. If you bridge rectify the HT winding of an Allied 6K27VF power trafo, 7+ mA. of "160" V. B+ are available for each triode. The filament winding is hefty enough too.
Eli D. |
| Where to buy kits Or best SS kits | Kitarist | Solid State | 1 | 8th February 2009 12:03 AM |
| Help with Decware SE84 Kit! | eeyore | Tubes / Valves | 1 | 27th January 2009 05:21 AM |
| Decware DFR8 | Jamesuk1 | Full Range | 23 | 15th January 2009 05:40 PM |
| Decware OB: is this possible? | pjanda1 | Full Range | 3 | 29th January 2008 04:51 AM |
| Decware ZSLA buffer -- worth cloning? | ssmith | Tubes / Valves | 6 | 17th October 2007 07:25 AM |
| Page generated in 0.08442 seconds (79.96% PHP - 20.04% MySQL) with 10 queries |
