diyAudio Sponsor
Old 26th January 2010, 01:37 PM   #1
Default Regulate HV preamp with floating LM317?
I have working all-octal Aikido headphone amplifier. Would there be benefit regulating the power supply with floating LM317 like this:
http://www.diyaudio.com/forums/attac...voltsupply.gif
I know I would probably gain more tighter bass and less PS ripple. But are the overall sonics better with or without this floating LM317?
Thank you.
Old 26th January 2010, 04:39 PM   #2
Arnulf is offline Arnulf  Europe
What kind of benefit ? Aikido is suppsoed to have superb PSRR (according to its author, at least). Why bother with additional voltage regulation then ?
If you're encountering noise from B+, you should IMO make sure that noise injection is working properly, with correct magnitude.
Old 26th January 2010, 05:17 PM   #3
SY's Avatar
If you have PS noise in the circuit (the PSR of the Aikido is good, but not anywhere near perfect), it may be of some help; I regulated one of mine just for that reason. If your rails aren't bouncing around and the preamp is quiet, it's probably not worth the bother.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 26th January 2010, 05:43 PM   #4
Preamp is quiet. I thought about regulation just for sonic benefit. Good shunt regulation would gain gain sonics benefits for sure, but I am not sure about floating LM317 series regulator.
Old 26th January 2010, 05:47 PM   #5
SY's Avatar
Nope, most of the sonic improvements come from the choice of tube and operating conditions; as long as the power supply is reasonably quiet and your line voltages don't vary much, the reg is a "nice to have" but not a game-changer.
Old 26th January 2010, 05:51 PM   #6
I know that using regulator will not drastically change sound. But if this series regulator will improve already good sound then I will do it.
HV SMPS for tube preamp Johan_Ch Power Supplies 8 6th December 2010 04:31 PM
looking for hv power supply kit for car tube preamp tomat Parts 6 7th December 2008 02:48 AM
simple HV rail splitter/floating ground - would this work? Rodeodave Power Supplies 3 20th July 2008 04:12 PM
Floating supply in battery powered discreet preamp aletheian Solid State 3 28th March 2007 04:42 PM
Regulate the high voltage making better sound? (Preamp) 9999 Tubes / Valves 20 20th January 2005 05:21 PM
Page generated in 0.07577 seconds (74.08% PHP - 25.92% MySQL) with 10 queries
