| diyAudio Sponsor | ||
Dear All,
Do you have/use any program from tubecad ? They look interesting, but the description is so convoluted that it's not clear what they do and what they don't do. Any experience ? Are they worth the money ? Best Regards, Davide |
#2 |
I have them and recomend them highly.
Bottom line, they are designed to model 1 stage at a time. If you give me an example project, I could provide a few screen shots. Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#3 |
I use both. Tubecad great for preamp stages. SE Cad is for power triodes in SE. Most tube types are there but SE Cad doesn't allow me to add new tubes to the library. I like to play with 6sn7 and others small tubes for SE outputs.
Good programs, worth the money if you need them.
Good sound comes and goes. |
#4 |
I am playing now with KT88 amp. I did the one with 6n1p and kt88 and the simpleSE from tubelab. I'd like to optimize cathode resistance, B+, and load to have minimum distorsion. The optimum would be to have a FTT Analyser, but it's far too expensive.
At the moment I have the standard configuration Cathode 560 ohm, B+ 422, load 5000ohm. Does tubecad estimate distorsion ? Thanks, Davide |
#5 |
TubeCad SE does estimate distortion.
#6 |
Here is a run with it at near maximum input.
Note that it took less than 5 min to do. Doug
#7 |
In the description of TubeCad SE it says it's for Triodes. The KT88 is a Pentode. How does it address using Pentodes?
#8 |
It addresses Triode connected Pentodes only.
| TubeCad Feedforward Shunt Regulator | jayme | Tubes / Valves | 1 | 5th May 2007 02:55 PM |
| Tubecad soft-clipping circuit | Dusk | Tubes / Valves | 2 | 15th January 2007 08:52 AM |
| tubecad is back | reinhard | Tubes / Valves | 7 | 17th November 2004 04:55 AM |
| TubeCAD | Le Basseur | Tubes / Valves | 0 | 14th May 2004 07:43 PM |
| Tubecad is back up and running | jackinnj | Tubes / Valves | 0 | 3rd December 2002 10:29 PM |
| Page generated in 0.08677 seconds (75.83% PHP - 24.17% MySQL) with 11 queries |
