diyAudio Sponsor
Old 22nd January 2010, 03:45 PM   #1
Default pre-amp tubes: matching and care
New to the tube scene. I have a pre-amp with 6 Sovtek 12AX7LPS tubes that need replacing. Compatable replacements are $4 to $100 ea. A guy on CL has some nice JAN Philips 12AX7WA for $30 ea, unmatched and ungraded. Is it critical to match tubes in a pre-amp? Are cryo treated 7025 worth the money? Is there a break in procedure. Is it true to not touch these with your fingers?
thanks
Old 22nd January 2010, 04:13 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
It unfortunatly depends on your circuit topology. For instance
a cathode bypassed common cathode amp with cathode self bias will be sensitive to Mu variations, so the gain from tube to tube will vary if not matched.
There are other (Triode in this case) topologies that are less sensetive to Mu.
If you could post a schematic it would be most helpful.
Not in my book, but neither are cryo treated rifle barrels, or bananas.
They may change sound profile as they break in, however there is no set procedure that I'm aware of.
thanks
Probably best not to get finger oil on them as they get hot. However it should not cause a change in performance.
Cheers.
Old 22nd January 2010, 04:17 PM   #3
SY's Avatar
Cheers.
+1.
I'd stay away from designer stuff and collectors' items. So far, the JJ's are the best I've tested and they're under $10.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 23rd January 2010, 12:10 AM   #4
The Sovtek 12AX7LPS is a very good tube and very likely better than Philips JAN.
Drop Jim McShane a note stating the equipment to be retubed. Jim will tell you whether or not you need culled tubes and why. A straighter shooter you'll not find.
Eli D.
Old 23rd January 2010, 03:09 PM   #5
Default Wow
Thanks Guys. I', still stoopid. Whats JJ'S tubes? I'll look for a schematic
Old 23rd January 2010, 03:37 PM   #6
zigzagflux's Avatar
Actually not a what but a 'who':
JJ-Electronic - Vacuum tubes, Capacitors, Amplifiers - Home
Old 23rd January 2010, 03:41 PM   #7
JJ is a tube manufacturer whose plant is in Jamona, Slovakia.
Sovtek and ElectroHarmonix are brands used by New Sensor on the products of their Saratov, Russia, plant.
Eli D.
Fender always taking care of tubes.... Cassiel Tubes / Valves 2 28th May 2009 02:30 PM
c-j pre amp blowing tubes? pforeman Tubes / Valves 8 12th March 2009 09:46 AM
adding output tubes etc to pre amp pforeman Tubes / Valves 1 2nd February 2009 06:02 PM
Tube power Amp matching with SAE Mark M pre amp and AR18 speaker or MS 25i soultribe Tubes / Valves 1 13th August 2006 11:08 AM
Pre to Power - amp matching JDeV Tubes / Valves 10 27th September 2003 05:26 PM
Page generated in 0.08722 seconds (78.95% PHP - 21.05% MySQL) with 10 queries
