diyAudio Sponsor
Old 18th January 2010, 10:51 PM   #1
Default Wintersweet highvividity driver circuit
Linear General Driver circuit for multiple power Triodes, derived from the Wintersweet Highvividity cathode follower power amplifier.
Please criticize. I will modify it to better fit your needs.
Old 19th January 2010, 12:58 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Why not take op-amp feedback from the cathode output? Or for that matter, from the output tube plate, or better still, the output itself?
I think you forgot the cathode follower's load resistor. :P
For that matter, negative supply to the first triode's cathode would give useful output range; I suppose the output tube is actually standing on like 100V or so (this is not indicated).
The 10k "grid leak" on the NE5532 is a bit small relative to the "10-100k" input pot -- 100k or even 1M would be better. Alternately, you can nix the coupling capacitors altogether and apply a small negative bias to the feedback node, same thing.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 19th January 2010, 02:48 AM   #3
Question answered:
"Why not take op-amp feedback from the cathode output? Or for that matter, from the output tube plate, or better still, the output itself?"
This is because I do not want to include the coupling capacitor in the feedback loop. The feedback loop operates down to DC, like any operational amplifier. Maybe it is fine to do what you suggested, but I have not done any experiment with that.
"I think you forgot the cathode follower's load resistor. :P
For that matter, negative supply to the first triode's cathode would give useful output range; I suppose the output tube is actually standing on like 100V or so (this is not indicated)."
I am aware of that :P. It is deliberate. I heard that this arrangement "sounds better" and from theoretical point of view, maybe it is fine too. Think of the "infinite equivalent leak resistor". I need to think it over in depth, but it is the amplifier builder's problem (It is part of the output stage and not part of the driver) and not mine.
"The 10k "grid leak" on the NE5532 is a bit small relative to the "10-100k" input pot -- 100k or even 1M would be better. "
the "leak resistor" was used to make the linear input pot more "exponential like". If you use an exponential input pot, then yes, a higher "leak resistor" will have less influence on the pot.
"Alternately, you can nix the coupling capacitors altogether and apply a small negative bias to the feedback node, same thing."
I did not do this because I did not want a capacitor in the feedback loop. Yes, a resistor-capacitor network on the feedback node is part of the feedback path. In this sense, an input operation amplifier should use the positive input node to take input, and the negative input node to take feedback. In my case, negative for input and positive for feedback.
OK, maybe I am too defensive. Thank you for your insights, my answers are but some clarifications of my design trade-offs and they do not mean to "fight back".
Old 19th January 2010, 03:49 PM   #4
Sch3mat1c's Avatar
You could remove that coupling capacitor then -- the first triode (and op-amp) will have to run from -V, but they'll also set the output tube bias, which will be very stable. You even have the opportunity to split feedback (oh noez, caps in the path!), so it's AC feedback to the grid or plate, DC feedback to the cathode current, so it's current servoed. It's still stable down to DC, the caps just move it to a slightly different method which works better.
Eww, that doesn't work. You get a big jump at the first couple degrees, then a whole lot of nothing, then the rest of the range. It doesn't feel right at all. The only thing that works right is a log pot with a high resistance load (at least 10 times the end-to-end resistance).
No, you don't need a cap, the bias divider can be supplied from regulated voltage alone. Don't need the 4.7uF bypass (but it's a good idea for noise anyway).
Tim
Old 19th January 2010, 04:32 PM   #5
You could be right. My design is to demonstrate that linear driver can be the best driver. The power stage itself can solely be responsible for producing the "tube sound". Your suggestions serve that purpose equally well.
I followed the design on this page: Better Volume Controls, ESP - A Better Volume Control
You could be right.
Wintersweet HighVividity Amplifer finalized HighVividity Tubes / Valves 11 8th December 2009 06:38 AM
The Wintersweet High-Vividity Project HighVividity Tubes / Valves 4 1st August 2008 06:50 PM
Simple balanced driver circuit. Graham Maynard Solid State 12 24th April 2007 06:46 AM
Will this MOSFET-driver circuit work? Danko Power Supplies 7 24th June 2005 02:09 PM
Circuit simulation using driver impedances. prash Multi-Way 3 13th July 2002 05:10 PM
Page generated in 0.10397 seconds (82.78% PHP - 17.22% MySQL) with 10 queries
