| diyAudio Sponsor | ||
Hi All, I have a couple amps in the works and trying to save a bit of money and using parts on hand. I have an AZ1 rec tube and socket and want to use it but I see that it is 4v on the filly vs 5v on most everything else. So, I my transformer, how can I take the 5v lines and knock them down to 4v for the AZ1??? Cheers.
#2 |
Easiest way is a dropping resistor in series with the filaments.
If you have a 5V supply and need 4V, you only need to drop 1V. Divide 1 by the filament current of the AZ1 and that is the resistor value you need. |
#3 |
Up to this point, I have been a kit type builder. Can you explain a bit more. Not sure I am catching what you are saying. Thanks in advance.
#4 |
put 1R/3W in series with AZ1 fill.
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#5 |
Be careful that the AZ1 has enough current potential for an amp - it's not the most robust rectifier out there.
500v - 60mA 400v - 75mA 300v - 100mA More of a preamplifier tube really. andy |
| Voltage drop AZ1 = AZ11 = RGN1064 rectifier tube | Klimon | Tubes / Valves | 2 | 29th June 2005 10:19 AM |
| Az1 mounted on wood! | barossi | Tubes / Valves | 9 | 13th June 2004 03:46 PM |
| nedd az1 tube base in the UK | Raj1 | Tubes / Valves | 6 | 28th September 2003 03:09 PM |
| rec. for creative ideas for alternative tube amp chassis | zobsky | Tubes / Valves | 21 | 30th August 2003 12:51 AM |
| Page generated in 0.08249 seconds (69.15% PHP - 30.85% MySQL) with 10 queries |
