| diyAudio Sponsor | ||
I am just finishing putting together the chassis for a couple of push-pull 300B amplifiers, and have a couple of questions about the UX4 sockets I have. I don't know what the origin of these sockets is (I bought them through Hi-Fi Collective in the UK, if that's any help), but they are made of a shiny white ceramic material and have a copper rivet through the base to secure each of the four connections. I am mounting these to the underside of the top plate, and have made a 35mm diameter hole for the base of the valve.
I have two questions: - Is there a standard diameter for the base of a 300B? I can't see this measurement on the datasheets I have found so far (I am intending to use JJ valves, by the way). Is 35mm likely to be a large enough cutout? - Has anyone used sockets like these with the copper rivets showing on top? They will be 3-4mm below the level of the top plate if I mount the sockets flush, and inset from the edge of the cutout by about the same distance. Should I worry about arcing from the 400 volts on the anode? Thanks, Alex |
#2 |
Your description fits the cheap Chinese sockets to a "T". My advice is get proper sockets.
If it looks like this it is the cheap one. http://i18.ebayimg.com/01/i/000/a9/99/da29_2.JPG Get the (good) sockets and then cut the holes for them.
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#3 | |
I have already cut the holes, unfortunately, which puts certain constraints on the replacements. Alex |
#4 |
Alex,
Only the anode connection may be vulnerable to arcing. Reduce the vulnerability by covering that rivet with several thin coats of corona dope. Allow plenty of time for drying, between coats.
Eli D. |
#5 |
Look for EF Johnson parts. They're the same size. If these rivets are exposed, 400V is accessible to touch from the top - I'd want additional insulation...
#6 |
Couldn't one just use some ordinary enamel rather than the corona dope? 300B's "only" run at 400 V after all.
~Tom |
#7 | |
Built up layers of nail polish might very well do. Corona dope is 100% certain to work.
Eli D. |
#8 |
Some 5 minute epoxy should do the trick.
#9 |
I am about to start a st70 scratch rebuild. I have nos Amphenol with the molded in plate that I intended to use. Other than the connectors wearing out, older Amphenol sockets I have in other amps/radios still look fine. I am haveing second thoughts about using them, because the ceramics would look better, but some of the ceramic sockets I have seen don't fit up well, so I am not so sure of these. Regards, Dave
#10 | |
Alex |
| 300B Summer Build Question | JPeitzman | Tubes / Valves | 114 | 24th July 2008 07:27 AM |
| question on old tube sockets | jarthel | Tubes / Valves | 3 | 18th June 2007 10:32 PM |
| Question on 300B tubes from Parts Connexion | gjo | Tubes / Valves | 2 | 31st January 2006 05:18 PM |
| * 35 watt * 300B SE = super 300B + Class A2 | rick57 | Tubes / Valves | 4 | 13th July 2005 04:18 PM |
| Page generated in 0.10368 seconds (79.86% PHP - 20.14% MySQL) with 10 queries |
