diyAudio Sponsor
Old 18th January 2010, 12:51 AM   #1
Default Unity coupled power stage
Hello,
I am a new member ,located in Germany 49 years old and since the age of 14 I have been fascinated by some glowing parts in a radio.
After some years of being occupied with other things, I would like to build another tube amp.
I have been attracted by a design called "unity coupled" formerly used by McIntosh.It seems that it might be possible to design a tube amp with all the advantages of such a unit combined with a higher damping factor than in conventional tube amp designs.
I own some Telefunken V69's and like them much but would prefer a better speaker control the low frequency range.
Has anyone made some experiences with a unity coupled design,perhaps with the Van der Veen toroidal output transformers?
Greetings from Germany Ralph
Old 18th January 2010, 02:10 AM   #2
If you are going to get involved with unity coupled design, study Frank McIntosh's designs, like the MC240.
Completely different in topology is the Harman/Kardon Citation II, but it too controls woofer voice coils very well. Plitron offers toroidal O/P "iron" with the bandwidth needed to "replicate" Stu Hegeman's design.
Eli D.
Old 18th January 2010, 02:21 AM   #3
smoking-amp's Avatar
Jan V. did a Mac project:
BigMac, Unity coupled output amplifier
Likely some threads here on diyAudio too. Seach for McIntosh or CFB or unity gain.
Ohms Law V = I R
Old 18th January 2010, 10:21 AM   #4
search also for 'LW6-180' an design using TV sweeps.
The unity coupled design requires large drive voltage swing; it is moderately troublesome. There are a few ways to solve it. Examine the 12BH7 part of the McIntosh circuits( on the 75/275 for example ). There is positive FB there to deliver the headroom required. One can deliver the headroom without positive feedback by substituting a CCS for the 12kOhm resistors( the 12BH7 plate loads ).
cheers,
Douglas
the Tnuctipun will return
Old 18th January 2010, 11:27 AM   #5
thank you for all the answers.I knew that the unity coupled design is a bit tricky because of the recommended high voltage swing for driving the output tubes.I considered a common cathode phase splitter as first stage followed by a mu stage driver in combination with a white cathode follower.(comments welcome...)When I find the time needed I will mount these stages for doing some measurements before buying the "iron".
Ralph
Unity coupled circuit amplifier. jane Tubes / Valves 6 23rd February 2011 05:50 PM
heretical unity gain OUTPUT stage... andrew_whitham Tubes / Valves 4 9th December 2006 03:36 AM
Unity coupled power amp TubeGuru Tubes / Valves 0 7th December 2006 02:18 AM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
A Heretical Unity gain line stage SY Tubes / Valves 85 22nd June 2005 11:37 AM
Page generated in 0.07652 seconds (74.44% PHP - 25.56% MySQL) with 10 queries
