diyAudio Sponsor
Old 17th January 2010, 03:52 PM   #1
pointy is offline pointy  United Kingdom
pointy's Avatar
Default what would happen if.........?
if i connected 2x bridge rectifiers to the same transformer and then connected the 2 +out puts together.
would i then get humps above zero or only the same as with 1x bridge rectifier.
Old 17th January 2010, 05:29 PM   #2
DougL is online now DougL  United States
If I understand correctly, It would be the same.
However, since the devil is in the details, a schematic would change "I think" to "I know".
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 17th January 2010, 06:04 PM   #3
pointy's Avatar
i was not certain that they would stay in phase
Old 17th January 2010, 06:19 PM   #4
Arnulf is offline Arnulf  Europe
What is "in phase" with full wave rectification ?
Your first post omitted one key detail (the fact that both bridges are connected to the same ground), changing what would initially be "nothing much" into "depending on how well the diodes are matched" reply.
If diodes are matched well, current capacity will double. What is more likely though is that they will not be matched well, one set of diodes will conduct majority of the current and the other next to none (with these diodes not biased enough to conduct as much as the other set).
Why would you want to do something silly like that anyway ? If you need more current capaity, use beefier diodes.
Old 17th January 2010, 06:23 PM   #5
pointy's Avatar
if it worked out of phase there may be less need for a choke
Old 17th January 2010, 07:51 PM   #6
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
First of all, why?
What you propose will increase the current capacity by connecting diodes in parallel. The diodes will not share current evenly and will be prone to thermal runaway. A ballast resistor must be placed in series with each AC terminal (or alternately, each DC terminal, but not both, which would be redundant).
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 17th January 2010, 08:08 PM   #7
pointy's Avatar
WHY?..................... it's sunday afternoon i was bored, and then i had this strange idea that it may stretch the top of the humps and overlap them down near zero.
"it was just some odd idea"
Old 17th January 2010, 09:40 PM   #8
A+ for thinking out of the box.
Doug
Old 17th January 2010, 10:17 PM   #9
pointy's Avatar
don't you meant thinking while out of my box.............!
"iv'e not had much sleep lately"
Old 17th January 2010, 10:29 PM   #10
kevinkr's Avatar
High Pointy, since the diodes are in parallel they are seeing the same ac phase and as a consequence there will be no difference between a single diode and two in parallel. The power available on that secondary is single phase.
Note that there are multi-phase rectifiers designed to run on 3 phase and in fact what you where thinking about is more or less the case there. So in a 3 phase system 100Hz full wave ripple becomes 300Hz ripple which is much easier to filter, and the period of each ripple component is a third of that found on single phase.
Unfortunately there is no convenient way to convert single phase ac to 3 phase ac as the phase relationships between each phase are 120 degrees in 3 phase as opposed to 180 degrees in single phase.. Usual methods include electronic or rotary converters.
Center tapped transformers running on single phase are still single phase with a phase relationship of 180 degrees between any two taps on the same winding.
Here is a site that explains 3 phase power as a point of interest: 3 Phase Transformers and Three Phase Power Transformer Models - The 3 Phase Power Resource Site
www.kta-hifi.net
what would happen if... aletheian Tubes / Valves 8 14th September 2005 03:34 AM
What happen with this transistor? lumanauw Solid State 22 19th February 2005 12:41 PM
Is it normal for this to happen? xstephanx Subwoofers 16 14th January 2005 02:26 AM
What happen to my sub! Mikka Multi-Way 22 7th October 2002 01:16 AM
Page generated in 0.10636 seconds (79.58% PHP - 20.42% MySQL) with 11 queries
