diyAudio Sponsor
Old 17th January 2010, 07:04 AM   #1
Default 300b socket
Sorry for the dumb question: the 300B can be inserted in any direction in the socket ? I have two sockets that do not seem to have any indication of pin number. Does it mean I can use them in any direction, and just be careful how I put the tube in ?
Thank you for help.
Best Regards,
Davide
Old 17th January 2010, 07:54 AM   #2
analog_sa's Avatar
You will notice that you cannot put them in "any" direction, so don't worry.
Old 17th January 2010, 02:50 PM   #3
Look carefully at the sockets and you should notice 2 of the holes being larger than the other two, there are two corresponding larger pins on the tube, these are the filament holes / pins so you SHOULD not be able to insert the tubes incorrectly.
I say should not because there are low quality sockets around with holes that an "overzealous" person would be able to insert the tubes in an incorrect way.
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 17th January 2010, 10:16 PM   #4
kevinkr's Avatar
I have run into a few of those low quality sockets myself, (relatively inexpensive Chinese made ceramic sockets) it takes a fair amount of force to do it, but I have seen the consequences first hand. Note that this is also possible with some expensive teflon types as well.
www.kta-hifi.net
Old 18th January 2010, 12:49 AM   #5
Yes, the cheap Chinese ones. I remember trying to bend the solder tab of one slightly to get a better angle and the tab simply broke in two, the solder tab in my fingers and the other part still riveted to the socket.
The thing that gets me though is I have seen a couple amps with these really cheap low quality sockets and high dollar boutique parts, you would think one would get the basics down first and then "flitter" the money away.
Oh well.
Old 18th January 2010, 07:31 AM   #6
I think I got it, my problem was that I have the socket, and I wanted to put them on a board, but I don't have the tubes yet.
Statistically I got it 50% correctly, guess I will have to cry a bit to desolder the wrongly mounted socket from the board :-(
Thanks,
Davide
Socket for 6AQ5 Stuey Tubes / Valves 28 22nd January 2009 08:39 PM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
316A socket mono_plate Tubes / Valves 2 20th September 2008 05:32 PM
Help on tube socket dung0981 Tubes / Valves 6 5th August 2006 08:31 AM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
Page generated in 0.09384 seconds (81.04% PHP - 18.96% MySQL) with 10 queries
