diyAudio Sponsor
Old 17th January 2010, 01:00 AM   #1
Default Vertical vs. Horizontal – does it matter?
Are there any implications or considerations for mounting tubes vertically or horizontally?
Are there difference between small signal triodes, power pentodes and HT rectifiers?
Old 17th January 2010, 01:09 AM   #2
jmilch is offline jmilch  United States
The original datasheet will tell you what mounting limitations a particular tube may have.
Old 17th January 2010, 01:26 AM   #3
Thanks.
1. Most data sheets don't mention this issue.
2. Even for tubes that the data sheet says they can be mounted either way, there may be some issues related to mounting position, like sound quality, immunity to vibrations and lifetime.
Therefore my questions.
Old 17th January 2010, 04:26 AM   #4
kavermei's Avatar
Send a message via MSN to kavermei
If you want to mount tubes horizontally, it is usually best to make sure that the posts which support the grid wires are in the same vertical plane. Otherwise the grid wires may sag because of the heat, and at one side will come closer to the cathode while on the other side coming closer to the anode. That would change the characteristics of the tube.
Never send a human to do a machine's job. --Agent Smith
Old 17th January 2010, 06:09 AM   #5
analog_sa's Avatar
Yes, DHTs can even fail if mounted horisontally at the wrong angle.
Old 17th January 2010, 06:59 AM   #6
Thanks.
What's DHTs and which angles are wrong?
Old 17th January 2010, 08:00 AM   #7
analog_sa's Avatar
I'll leave to someone else to explain what's DHTs If the filaments are not perpendicular to ground they may eventually sag and hit the grid.
Old 17th January 2010, 07:53 PM   #8
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Directly heated rectifiers also recommend this, e.g. 5Y3, 5U4, etc. I suppose the grid is closer to the filament in a triode than a rectifier, making this an even greater concern.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 17th January 2010, 08:30 PM   #9
pointy is offline pointy  United Kingdom
pointy's Avatar
the internal heating will be different due to thermal lift. also some of the external wires may sag and short in horizontal mode.
Old 18th January 2010, 01:17 AM   #10
Sch3mat1c's Avatar
Well, the envelope will be hotter on the top side unless you use a fan (and if you have a lot of tubes crammed inside, that's a good idea, as Tektronix did back in the day). In a vacuum, heat knows no gravity.
Tim
Horizontal or vertical? dobias Multi-Way 7 11th August 2009 03:41 PM
Vertical/Horizontal 2 x JXR6 Linear Array as central speaker ? fvaille Full Range 6 11th January 2009 10:20 PM
Vertical MT, horizontal woofer fb Multi-Way 5 14th October 2008 09:55 PM
Horizontal vs. Vertical Alignment Pano Multi-Way 2 12th November 2006 09:14 AM
lateral vs vertical,P vs N Leolabs Pass Labs 3 15th February 2005 06:01 PM
Page generated in 0.09599 seconds (81.38% PHP - 18.62% MySQL) with 10 queries
