diyAudio Sponsor
Old 16th January 2010, 10:12 PM   #1
Default Layout thoughts hmm....
So with these different layouts does a person have to worry about hum and what not from the rectifier tube much?? Just playing around with some different layout ideas and thought I would share.
#1
#2
My first simple se running some 6l6gc, that needs some finishing yet on the chassis.
Old 17th January 2010, 01:34 AM   #2
HollowState's Avatar
In my opinion either of your proposed layouts will provide excellent results assuming below deck wiring is done with the usual proper care. Which of the two you use is strictly a matter of what pleases you aesthetically.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 17th January 2010, 05:43 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Put the power transformer on the opposite end of the OPTs. If you're going to make it rectangular, this will do an excellent job of spreading things out. In terms of distance, #2 is basically the worst possible layout.
At the very least, swap position of PT and rectifier in the first, so the PT can be slightly farther away from the OPTs. No, it doesn't look good, but you asked for best, not prettiest.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Guitar amp layout second thoughts mashaffer Tubes / Valves 2 24th April 2008 01:26 AM
my ad1853 layout.. thoughts? costiss Digital Source 16 17th June 2005 06:28 PM
Hmm, what a coincidence.. Sch3mat1c Everything Else 6 7th March 2003 10:54 PM
hmm.. help with mosfets Colt45 Solid State 5 27th August 2002 07:08 AM
Page generated in 0.07115 seconds (73.82% PHP - 26.18% MySQL) with 10 queries
