diyAudio Sponsor
Old 16th January 2010, 07:57 PM   #1
Default Anyone got any info on the Tippatone 500 watt amps?
Like schematics, valves used etc people often baulk at big wattage amps but all the Jamaican sound systems were bouncing with that kind of power!
Old 17th January 2010, 05:25 AM   #2
Never heard of the amp but found this:
YouTube - our valve amp
Old 17th January 2010, 05:53 AM   #3
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I doubt it very seriously if this amp as depicted in the video is putting out 500 Watts of output power.
Do you have a clue how hard it would be or how heavy....or how much power would be consumed to generate this level of output power with a tube amplifier?
More than likely the reference to 500 Watts is the power CONSUMED........& not the power output.
Just the output transformers would be the size of a basketball................let alone the B+ main, the chokes, the filament TXs' et. al.
__________________________________________________ ______Rick......
Old 17th January 2010, 06:27 AM   #4
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Never mind the amp.
Is that Garrard 4HF ?
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 17th January 2010, 06:11 PM   #5
The Champ is purported to be 1000 watts
Champ 1000 Watt Tube Amp
Old 18th January 2010, 04:47 AM   #6
this is cool too
1000w EL6471
Old 18th January 2010, 04:54 AM   #7
Bob_345 is offline Bob_345  United States
crate made a 600 watt all tube guitar amp. 25 tubes and a 12x16 cab. crazy stuff right there YouTube - The loudest tube guitar amp in the universe...
Old 18th January 2010, 04:58 PM   #8
That EL6471 looks so cool, class B though... I was hoping for 'at worst' AB1 (triode).
And those guitar amps are crazy! I was hoping to put together a 100/200 watt bass guitar amp using triodes, probably use 304TL or similar
IcePower 500 watt Evaluation Kits Daytona50 Swap Meet 0 4th March 2009 08:15 PM
Help With A 500 Watt subwoofer and a 1000 amp Bgpoet Solid State 2 30th December 2008 07:41 AM
need 500 watt subwoofer amp kit gompka Solid State 7 19th February 2006 01:29 AM
500 watt monoblock RogerG Solid State 45 12th April 2005 01:05 PM
500 Watt Op Amps from Apex Microtechnology jasonc Chip Amps 22 26th March 2004 04:12 AM
Page generated in 0.09155 seconds (76.82% PHP - 23.18% MySQL) with 10 queries
