| diyAudio Sponsor | ||
Some of the pins of the EL84 are shown as IC (Internal connection I suppose).
Is it safe to use these as tie points? Here's an example: The Hazen mod uses the separated suppressor connection on pins 1 and 6 of the SV83/6P15 but these are "IC" on the EL84 datasheet. If I build an amp with the Hazen-enabled 6P15 and then want to use an EL84 (I know the Hazen won't work with EL84) in the same circuit, do I have to unsolder the connections to pin 1 or 6? Don't want to damage my precious NOS Philips EL84s ![]() Gary |
#2 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Greetings from FixitLand!
Caveat on using 6BQ5's in modern EL84 amps! I would leave pins 1, 6 and 8 open. In fact, I *did,* in my "AMP II." That way, I can use a 6BQ5/EL84, 7189 or 7189A interchangeably. Take care, -- J. E. Knox 'The Victor Freak' |
#4 |
Thanks, Sy. I'll have to try and remember to unsolder them when I finally knock the 6P15 Hazen version up. I currently have the EL84s in stereo SE driven by a 6N3P-EV and it sounds very nice, and wanted to try 6P15-EV with Hazen mod for comparison.
Gary |
#5 |
Thanks rojoknox. Interesting post that, especially cutting the pins off the tube. Yikes!!
| Correct Pins For EL84 Triode Strap | TV Man | Tubes / Valves | 4 | 29th March 2009 09:31 AM |
| is it safe to connect these secondaries in series? | jarthel | Tubes / Valves | 3 | 15th June 2007 12:28 PM |
| 74ac02 unused input pins | tonitze | Digital Source | 19 | 23rd April 2005 02:41 PM |
| NS LM478x series chips with pins that say "no connect". | captain | Chip Amps | 4 | 8th November 2004 06:23 AM |
| Hakko 936 - ESD safe vs. non-ESD safe | KT | Parts | 2 | 20th June 2004 03:58 AM |
| Page generated in 0.07853 seconds (75.85% PHP - 24.15% MySQL) with 10 queries |
