diyAudio Sponsor
Old 15th January 2010, 04:12 AM   #1
Troncones's Avatar
Default Zenith 7B31 Help
Any body rebuilt one of these as a stand alone amp? How did you bias the amplifier tubes (12AU7)? Most of the bias feed back circut is in the preamp that I don't have.
As a foot note these things must have been as piece of crap in thier day. On mine the insulation on the 355V feed has been burned through in two places by power resistors placed against them. The best I can tell it was this way from the factory.
Old 15th January 2010, 01:06 PM   #2
Troncones's Avatar
Actually the question should be; what did you the replace the Mid Mue 12AU7 with and how did you bias it?
zenith amp diesel_tech Tubes / Valves 6 22nd October 2007 01:34 AM
Zenith Amplifier bonsai171 Tubes / Valves 4 18th May 2005 12:18 AM
Zenith Turntable LUIZ Analogue Source 3 19th March 2004 07:09 PM
Zenith Wavemagnet Help Please !!! AdvanceTech Tubes / Valves 3 11th March 2004 06:55 PM
Page generated in 0.05333 seconds (68.55% PHP - 31.45% MySQL) with 10 queries
