diyAudio Sponsor
Old 14th January 2010, 08:25 PM   #1
tomchr is offline tomchr  United States
tomchr's Avatar
Default Differential input, SET output
I'm mulling over the design of a 300B amp. I want to run the 300B as a single-ended triode. The rest of my audio chain uses differential signaling so I would like this 300B amp to have differential input.
One could, of course, just ground the (-) pin of the XLR connector and take the signal single-ended off the (+) pin, but that defeats the purpose of the differential signaling. Another thought would be to start with a resistively loaded differential stage and use one of the outputs from it to drive the 300B (via appropriate cathode/source follower, etc). And finally, one could use an op-amp diff amp to deliver a single-ended signal to a normal single-ended 300B amp. Oh, and transformer input is also an option, though, in my humble opinion, not a viable one.
Of these options, I like the differential pair the best. But does it make sense to go about it this way?
~Tom
Old 14th January 2010, 09:04 PM   #2
leadbelly's Avatar
Look at kenpeters' work:
converting BAL to UNBAL using tubes and without transformers
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 14th January 2010, 09:27 PM   #3
Miles Prower's Avatar
Any differential input stage can do this, NBD.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 14th January 2010, 10:02 PM   #4
tomchr's Avatar
Sure, any differential stage CAN do this, but is that the best approach?
The diff pair is my preferred approach - mostly because I'm very familiar with it - and it looks like everybody else has arrived at the same conclusion.
thanks,
~Tom
Old 14th January 2010, 10:08 PM   #5
SY's Avatar
Why not? Something like a Jensen JT11-P1 or a Cinemag 15/15 would give you superb CMR, galvanic isolation, and have bandwidth and distortion well better than any SET is likely to have.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th January 2010, 01:07 AM   #6
Gordy is offline Gordy  United Kingdom
tomchr, I'm in the process of building a small SET with a balanced input served simply by an XLR feeding into a transformer, and then into a volume control attenuator, which then feeds into a driver tube before the output tube.
Nowt wrong with an input transformer!
Old 15th January 2010, 04:08 AM   #7
jlsem is offline jlsem  United States
jlsem's Avatar
Why not keep it differential right up the the 300B and use an interstage transformer to couple the driver to the output tube and convert to single-ended? This would be the best approach IMO.
John
Old 15th January 2010, 07:12 PM   #8
tomchr's Avatar
I was discarding transformers on the grounds of my preconceived notions of high distortion and high cost. Looking at the Jensen and Cinemag products, I definitely take back the "high distortion" part. Those trannies are IMPRESSIVE!! and offer CMRR that rival many modern op-amps. THD < 0.02 % even at 20 Hz! Nice. The Jensen is $80-ish. Cinemag don't publish prices. I'm a little afraid to ask. If you have to ask, you can't afford it.
Has anyone of you ordered from Cinemag and have an idea of the pricing?
I know interstage transformers have been used to drive a 300B in the past. I also understand that the 300B wants a low-impedance drive. I wonder what the output impedance of those interstage transformers are if they're driven by a source/cathode follower. I think that would be the bottleneck on performance of the system.
Thanks,
~Tom
Old 16th January 2010, 12:13 AM   #9
Thanks,
~Tom
Contact Steve Eddy. He switched from Jensen to CineMag because of favorable pricing.
A 6SL7/5751/7F7 SRPP should provide the voltage gain needed. An IRFBC20 in Tubelab's Power Drive will neatly take care of dragging a 300B's grid slightly positive.
Eli D.
My differential input 49830 Phil Olson Solid State 6 6th May 2012 11:38 PM
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
Tube differential input/buffer /w opamp output gainclone aletheian Chip Amps 2 23rd August 2005 07:36 AM
Page generated in 0.10779 seconds (79.21% PHP - 20.79% MySQL) with 10 queries
