| diyAudio Sponsor | ||
tarmac ripper
Ciao,
I am considering a EF184 (used as pentode) in a DAC IV-preamp. Bias should be in the 10-15mA/150-200V region. Does any of you have experience with this puppy in critical low level applications? I used it a while ago as CCS and I was quite impressed by the build quality (I think they were tunsfgram) and sound. Would you point me to other small pentode that can be biased at that current? I am not used to those tubes, sorry. Thanks Gianluca |
#2 |
The only small current pentodes i use are E180F/E280F/D3A. Very suitable for low level signals and work at similar currents. Higher transconductance than EF184. Out of curiosity: why as a pentode? Voltage gain is sufficiently high as triodes and you won't need an extra stage to get acceptable output impedance.
#3 |
I can vouch for the D3A, very quiet in general.. For this application I would think triode connection would be fine.. The tube has a mu of 77 and an rp that is <2K IME.. Who needs pentode partition noise in an application like this? (I am not sure how big an issue it would be, but as a pentode connection is probably not required....) Ideal for a single stage low noise amplifier with low output Z. Use a CCS or choke load and it will drive a 10K load quite happily..
www.kta-hifi.net |
#4 |
tarmac ripper
I'd like to use it as current to voltage device not as a voltage amplifer. D3A can be quite expensive maybe??!!
#5 |
Do you have a circuit in mind? Grounded grid? Cannot imagine tubes being ideal for this.
#6 |
tarmac ripper
GG? Hum... yes actually. With a servobias. It seems it works pretty on spice and as I have most of the parts (but the EF184) I'd like to give it a try.
#7 | ||
Can't help you with your project, all I can say is this tube sounds great. Geek knows this too. Quote:
Good sound comes and goes. Last edited by Cassiel; 14th January 2010 at 11:43 PM. Reason: grammar as usual |
#8 |
The EF184/6EJ7 seems to have a favorable opinion even though its considered a "tv" tube. The price is low so give them a try.
#9 | |
You ought to post your proposed circuit.
www.kta-hifi.net Last edited by kevinkr; 15th January 2010 at 02:45 AM. |
#10 |
tarmac ripper
| EF184/6EJ7 in Vox AC15 circuit. Who needs EF86? | Cassiel | Instruments and Amps | 22 | 18th March 2012 07:16 PM |
| Eagle users - help! | MikeHunt79 | Everything Else | 2 | 6th March 2008 05:09 AM |
| EF184 or (EC)L82 radio amplifier?! | Michael68 | Tubes / Valves | 4 | 19th December 2007 05:40 PM |
| For FooBar users - | percy | Digital Source | 2 | 21st May 2005 01:16 PM |
| ESG1 users ? | jonk | Multi-Way | 0 | 2nd September 2003 04:56 AM |
| Page generated in 0.10182 seconds (79.67% PHP - 20.33% MySQL) with 10 queries |
