diyAudio Sponsor
Old 14th January 2010, 01:56 AM   #1
Default Subbing in a TVC - input load Q
Gents,
If I take a 'standard' 100k volume pot out of a circuit and sub in a TVC; do I need to load the output of the TVC with a 100k resistor before the grid of the tube ?
Thanks,
Old 14th January 2010, 06:35 AM   #2
analog_sa's Avatar
No.
Old 14th January 2010, 09:03 AM   #3
Thanks for the quick reply !
Old 14th January 2010, 11:57 AM   #4
Previously: Kuei Yang Wang
ThorstenL's Avatar
No need to terminate the tube grid, a grid stopper is probably a good idea and you may wish to connect 100K across the whole secondary winding though.
Ciao T
Old 14th January 2010, 01:42 PM   #5
Yes - sorry; you stated this better than I did. This is specifically what I was trying to ask. I guess I can try either way once the amp is built when I to to test w/a square wave.
Thanks again,
Steve
TVC before Input Transformer? dre7 Tubes / Valves 6 25th October 2007 09:25 PM
Subbing Transistors Within A Unit DreadPirate Solid State 8 7th July 2006 04:12 PM
MC load, normal input characteristics peranders Analogue Source 34 1st October 2002 10:50 PM
Page generated in 0.07312 seconds (70.35% PHP - 29.65% MySQL) with 10 queries
