diyAudio Sponsor
Old 11th January 2010, 05:22 PM   #1
Default 6gk5/ECC88 Phono any comments.
Posted this on the Analogue source forum, where it was suggested i move it here.
Looking for a similar phono stage to the Garry Pimm/Kurt strain design but all tube.
Ht voltage is limited to around 260V. So i have chosen to use an ECC88 as upper section of the mu follower.
Any comments or suggestions on this proposed circuit? Whats the noise performance of the 6Gk5 in the front end of a phono?
Cheers.
Comments on 6gk5/Ecc88 Valve Phono Amp velvetsunrise Analogue Source 1 9th January 2010 03:37 PM
Operating point for 6GK5 AKSA Tubes / Valves 6 6th October 2008 03:21 PM
Copland CTA-402 Phono Section Comments Algar_emi Tubes / Valves 52 30th April 2008 06:12 AM
6GK5 to drive a 6AS7? G Tubes / Valves 7 27th April 2008 04:33 AM
6GK5 vs. EC95/6ER5 TheGatesOfFate Tubes / Valves 1 18th March 2005 08:00 AM
Page generated in 0.06116 seconds (66.29% PHP - 33.71% MySQL) with 11 queries
