| diyAudio Sponsor | ||
All right, I'm wiring up my power switch and I need to know which of the tabs on my DPST switch "go together"? Is the juice coming "in" the top and out the bottom or is it coming "in" one side and out the other?
I know, I know, stupid question! |
#2 |
...drink two more beers and then just wing it...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 |
#4 |
it can be... of course, it could also be short.
#5 |
#6 |
You really need to use a multimeter to determine the switch configuration.
Frank |
#7 |
post a schematic of the switch.
Otherwise, use an ohmmeter and check which contacts are connecting in each position. Ideally, the "live" side is the fixed contact and the "switched" side is the moving contact, but in reality it doesn't matter.
#8 |
Alright, with the help of my brand new multi-meter it appears that when the switch is off nothing happens regardless of what two tabs I'm touching. When the switch is on, I get a reading when I touch two of the side tabs. I'm assuming that means that these two "go together" and that the juice is going "in" one and "out" the other; correct?
I couldn't find the exact switch I purchased (forgot the model number) but I think I'm tracking now. |
#9 |
I wish the picture will give you some help and good luck.
#10 |
Just kidding, found the part bag and looked it up at Mouser
http://www.nkkswitches.com/pdf/stoggleslowcap.pdf Looks like 1 and 2 go together and 4 and 5 go together (those just happen to be the side tabs). Thanks for pointing me in the right direction. |
| Another stupid question! | Dxvideo | Chip Amps | 7 | 20th May 2007 03:46 PM |
| Stupid question? | Klimon | Tubes / Valves | 6 | 28th August 2005 11:47 AM |
| REALLY stupid question.... | Morse | Chip Amps | 44 | 20th January 2004 02:03 PM |
| Stupid Yes/No question | Elkaid | Solid State | 3 | 4th February 2003 08:26 PM |
| Page generated in 0.09110 seconds (75.61% PHP - 24.39% MySQL) with 11 queries |
