diyAudio Sponsor
Old 11th January 2010, 01:41 AM   #1
Default Max Current of James JS-6123HS Transformer
Hi, I see that this transformer is rated at 90ma primary current on some web-sites and 120ma pri current on others. Does anybody know what the saturation current is on these transformers? I have an amp planned that will run about 105ma on the primary and was wondering if this is too much? Anybody have experience with these transformers running at more than 90ma pri current? Thanks in advance... Daniel
Old 11th January 2010, 03:30 AM   #2
mwiebe is offline mwiebe  United States
Daniel,
I'm running them at 330V/92ma, SV811 A2, and there is plenty of bass, though that's with Visatron B200 open baffle. Not much of a data point I know. The spec' on the James website is 90ma at 20Ws, so my hunch is that 120ma around 300V would be too much.
Matt
Old 30th January 2010, 04:23 AM   #3
Default Depending on the load
I think 120mA is too much.
The factory measurement: For 2.5k load the recommended allowable primary current is 100.2mA (primary inductance 18.74H); 3.5K load is 80.33mA (primary inductance 19.545H), 5K load is 68.15mA (primary inductance 27.38H). Please note that all is measured at 500mV level and at freq 60Hz.
So, if you are using 2.5K load, 105mA i think is worth to try since the maximum before saturation is 120mA.
Old 30th January 2010, 12:31 PM   #4
Do you have a link for those James Data Sheets?
Matt
Old 30th January 2010, 02:49 PM   #5
I did the typo in regard to 6123HS. For 2.5K load, the correct primary inductance is 13.74H (not 18.74H) when measured at 100.2mA at 500mV level and freq 60Hz.
I don't have the link just right now. I got this from Euphonia Audio website before they colosed down the business some years ago. I have also some pdf docs for type 6133HS, 6135HS and 6157HS. Let me know if you need them.
I ordered a pair of 6135HSF (6135HS with feedback) directly from factory at Taiwan. They also sent me an individual test/ measurement paper altogether with the package. I test the primary inductance with my inductance meter, they are perfectly matched.
Old 30th January 2010, 05:58 PM   #6
Thanks for the offer. James respond quickly to email, I just never thought of asking them for that data. I'll give them a try at some point.
Thanks,
Matt
Who knows James 6123HS parameters? Or where to ask HighVividity Tubes / Valves 2 10th June 2009 02:59 PM
Using James JS-6123HS with EL84 SE is overkilled? nina Tubes / Valves 2 18th May 2009 05:04 PM
james 6123hs totaltech Tubes / Valves 4 29th August 2008 11:21 PM
WTB - James 6123HS Transformers... Guiness Swap Meet 0 10th June 2008 10:44 PM
Max 300B SE output possible with James 6123HS ? ashok Tubes / Valves 4 17th June 2006 02:07 AM
Page generated in 0.06902 seconds (79.89% PHP - 20.11% MySQL) with 11 queries
