diyAudio Sponsor
Old 10th January 2010, 01:35 PM   #1
Junior is offline Junior  Singapore
Smile Equivalent to IXCP10M45S?
hi,
had a hard time looking for the above mentioned chip locally.
i had spend the whole of sat asking ard but in vain.
so am here asking for the equivalent replacement chip for IXCP10M45S.
reason for asking cos' if i were to order from the states, the cost of shipping is more than 10 times the chip itself and thus certainly is not the way for me to spend my hard earn $ like that.
thanks
Old 10th January 2010, 01:54 PM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
You could order them from diyhifisupply in Hong Kong. I'm sure possible replacements will be just as hard to find. Such as DN2540 (Need to cascade them because performance of one is not as good as one 10M45S.) Or the IXUS 01N100D which has been reported as being better than the DN2540 soundwize)
What would be the best however in your situation would to build something like the C4S which uses common transistors but is known to perform and sound well.
Old 10th January 2010, 02:02 PM   #3
pointy is offline pointy  United Kingdom
pointy's Avatar
i thought it was the inxy10m45 that needs cascade and the dn2540 you could use as a single.
something to do with the b-e hot spot not being that big.............?
Old 10th January 2010, 02:14 PM   #4
You can use either cascaded or single. But I saw measurements by Gary Pimm:
CCS performance measurments
That show the performance of one DN2450 comparing not so favourably with a 10m45 if both are used single. The cascoded DN2540 has excellent performance.
Old 10th January 2010, 02:22 PM   #5
pointy's Avatar
at what sort of voltage was the test at................i was thinking for anode resistor replacement (150v +)
Old 10th January 2010, 02:36 PM   #6
Dunno. But from the duties Gary used them for. I'm guessing he also measured them in exactly the situations you'll be using them.
Old 10th January 2010, 03:03 PM   #7
pointy's Avatar
i have got a k+k cascode kit.......someday i will give it a try as a cascode and then single.
the only thing with that is in the cascode kit the lower mosfet is a IXTP01N100D.
so if you want 2x DN2540 you have to get 2 single kits.
Old 10th January 2010, 03:14 PM   #8
Sure it is not the top position? This guy also from the Uk shows it on top...and I think he uses the K&K ones as well. http://www.triodeguy.com/Triodeguy%2...%20Circuit.pdf
Old 10th January 2010, 03:23 PM   #9
pointy's Avatar
i just had a look at the paper work and your right.
Old 10th January 2010, 03:36 PM   #10
pointy's Avatar
any way the best in all cases is meant to be the IXCP10M45S cascode.
but you just can't get them in the UK. something to do with the supply contract.
Ixys IXCP10M45s IC tubelab.com Tubes / Valves 106 17th May 2010 09:36 AM
Fs: Ixys Ixcp10m90s, Ixcp10m45s, Dssk60-0045a luvdunhill Swap Meet 12 16th January 2010 11:26 AM
Wtb: Ixcp10m45s Junior Swap Meet 3 16th January 2010 01:14 AM
6P1 Equivalent rabidlistener Tubes / Valves 1 18th February 2008 06:48 AM
WTB IXCP10M45s woody Swap Meet 0 6th July 2007 01:28 AM
Page generated in 0.12020 seconds (78.41% PHP - 21.59% MySQL) with 11 queries
