What gives with this square wave? - Page 3 - diyAudio
Old 21st January 2010, 02:25 AM   #21
expert in tautology
bear's Avatar
Which is the HF and which is the LF?
Both look quite normal for a transformer..
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 21st January 2010, 10:31 AM   #22
martyh is offline martyh  United States
This is the LF @ 100 Hz. Top trace is generator bottom is transformer
Old 21st January 2010, 08:33 PM   #23
expert in tautology
bear's Avatar
Yep ur transformer is not too happy at LF... insufficient inductance perhaps, or else some other artifact of your test setup.
_-_-bear
_-_-bear
Old 21st January 2010, 09:22 PM   #24
HollowState's Avatar
Your transformer would have to be flat down to 10 Hz to pass that frequency without tilting. Also, your scope input must be DC coupled...not AC.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Microphone turns triangle wave into square wave? Circlotron Analogue Source 18 25th January 2003 06:44 AM
Copyright 1999-2017 diyAudio
