diyAudio Sponsor
Old 9th January 2010, 02:51 PM   #1
Default PP tube amp for bi-amping : above 400 hz
Hello
I am interested in getting a very high quality tube amp for mid & high frequencies (greater than say 400 hz) . It will be bi-amped altec rig (altec 416z on bottom; jbl 2440 on top + tweeter crossed at 800 hz). The main criteria is dynamics & quietness.
So far I think Push Pull offers better (much better) dynamics than Single-ended amps (even on a compression driver). So I am leaning towards a 10-25 watts Push-Pull amp as a first cut(I have been using 50 w push/pull on just compression driver - sounds crazy but it does sound great except for the noise-- I want the same sound&dynamics but without the noise). Are there any amps specificall designed for mid/high frequencies? I know good Power Supplies greatly improve bass performance. What needs to be done to optimiize mid/high frequencies?
So, do such amps already exist? Or I have to modify/build/commission such a mid/hi freq amp?
If anyone has any links, please let me know.
thks in advance
operafan4
Old 9th January 2010, 04:08 PM   #2
You want SET amp to feed high frequencies, especially compression driver. Use P-P amp for bass unit. With high efficiency horn tweeter, you only need 5-ish watts. Check out Tubelab SE amp in Tubelab section of this forum. It's got what you need.
Need help in building Ucd module based power amp for bi-amping Halook Class D 6 4th January 2010 02:47 PM
Bi amping adventfan Solid State 14 26th June 2008 03:28 PM
Getting only 400 hours on Class A2 PP tube qguy Tubes / Valves 13 19th June 2008 01:27 PM
Sonic Impact T-Amp - Is bi-amping better? ac2005 Class D 1 29th July 2005 09:28 PM
Bi-amping keyser Multi-Way 2 10th February 2005 11:57 AM
Page generated in 0.06738 seconds (70.55% PHP - 29.45% MySQL) with 10 queries
