| diyAudio Sponsor | ||
I have several 6SL7's and was needing an active crossover,I put togther the curcuit below,any suggestions?
#2 |
Why use a 6SL7? That's not a good choice for a cathode follower- what you want there is high transconductance and reasonably high current. ECC88, D3a, ECC99, that sort of thing. There are some topological issues, too, but let's get the tube right first.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Your "HF" and "LF" labels are reversed.
Cheers! |
#4 |
#5 |
The 6SL7 is indeed not appropriate, as the low transconductance implies in 'high' output impedance and... well, read this post that explains it all. Actually the whole thread should be of interest for you!
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY! |
#6 |
R.I.P.
SY is correct about the 6SL7 not being the best tube for the job - but you have a MAJOR mistake in the low pass circuit.
You will only have the grid/cathode V (maybe 2V) across the 40k cathode follower R = microamps of current. To make it work, even with 6SL7's - you will need to either elevate the grid like you have done in the hipass, or provide a negative supply to feed that 40k. Regards, Allen |
#7 |
Those are some of the topological issues. So is the dependence of the filter transfer characteristics on the source impedance.
I'll hold my tongue about using Sallen-Key.
| 6SL7 alternatives? | Cobra2 | Tubes / Valves | 19 | 10th September 2009 09:40 AM |
| 6SL7 5E3 - together at last? | atmars | Tubes / Valves | 12 | 24th November 2008 01:59 AM |
| 6sl7 | nhuwar | Tubes / Valves | 6 | 23rd August 2008 03:29 PM |
| 6sl7 | omom123 | Tubes / Valves | 0 | 23rd August 2007 07:11 PM |
| What's a 6SL7 Good For? | dsavitsk | Tubes / Valves | 23 | 28th March 2007 01:53 AM |
| Page generated in 0.06887 seconds (83.69% PHP - 16.31% MySQL) with 11 queries |
