How to choose an optimal load line for a cathode follwer buffer?
Old 10th January 2010, 04:56 PM   #11
manamanam is offline manamanam  Greece
Originally Posted by manamanam View Post
Thank you for your analysis and calculations.
These are very helpful.
I just cannot understand how do i determine min and max plate currents. The ECC88 datasheet states typical Ia=25mA. Also the follower is not directly connected to a next stage grid, it is just a buffer to drive a pair of active monitors with 10K input impedance.
Actually states Ia=15mA
Old 10th January 2010, 05:47 PM   #12
kavermei is offline kavermei  Belgium
kavermei's Avatar
Send a message via MSN to kavermei
After choosing the quiescent point (-7.5V in this example), you follow the load line from the quiescent point up to the Vgk=0V line. That is your maximum positive Ia swing since you don't drive the grid positive. Because the drive signal is symmetrical around the quiescent -7.5V, its minimum is at -15V. So you can read the maximum negative Ia swing from the intersection of the load line with the Vgk=-15V curve.
Never send a human to do a machine's job. --Agent Smith
Old 4th July 2012, 02:46 AM   #13
pingfloid is offline pingfloid  Thailand
pingfloid's Avatar
Hi. Thank you for all your contributions.
I am still confused about how to plot the load lines in a white cathode follower headphone amplifier
If I plot a line between maximum B+ (220V) and the idle conditions at the cathode resistor of the bottom tube (V= 2.4V, I= 8.9 mA) I’ve got this:
That gives an intersection at V=107.2V and I=17.5mA
Is it the curve for the tube at the top or at the bottom?
Old 5th July 2012, 01:52 AM   #14
pingfloid's Avatar
I forgot to mention that I wish to learn how to plot the lines in this case because I plan to substitute the output tubes for a couple of 6F8G (the 6SN7 in a big bottle) therefore I have to recalculate the resistors.
Any recommendations will be highly appreciated.
Old 5th July 2012, 03:13 AM   #15
Triodethom is offline Triodethom  United States
Triodethom's Avatar
The output cap can be smaller say a 47uf so you use a film cap sounds better the 12at7 can be run harder ( more current thru it ) What headphone are you thinking of using ?
Old 5th July 2012, 08:33 AM   #16
pingfloid's Avatar
Hi Triodethom.
I have already bought the output electrolytic caps (Jensen Audiograde 500uF/300V)
I am using Sennheiser HD650 (300 Ohm)
I find that if I run more current through the first tube, then the signals at the two output tubes are not balanced. I have found that values playing with Orcad, and the result is a nice symetric figure at the output tubes. Anyway, I will keep mixing values to see if I can find another lucky match running more current at the input tube.
(measuring from grid to cathode at each output tube)
Although I still don't know how this may affect the sound
Old 5th July 2012, 02:19 PM   #17
Triodethom's Avatar
Originally Posted by pingfloid View Post
Hi Triodethom.
I would use them as power supply caps. If you go to Broskie site Tube CAD Journal you will see that the output cap can be smaller than 47 uf for the output . That is film size it also saves you some subsonic rumble that muddies the deep bass .
How to choose an optimal load line for a cathode follwer buffer?Hide this!Advertise here!
Cathode Bypass caps - how to choose? JesseG Tubes / Valves 16 20th December 2016 11:13 AM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
Line Array vs. electrostatic for optimal SQL performance elves1111 Multi-Way 5 28th December 2007 10:50 PM
Mu-follower vs common cathode w/- active load jnb Tubes / Valves 7 24th June 2007 09:53 AM
Gas tube cathode load? Joel Tubes / Valves 4 8th January 2003 04:18 PM
Copyright ©1999-2017 diyAudio
