diyAudio Sponsor
Old 6th January 2010, 01:48 PM   #1
Troncones's Avatar
Default Olson AM-158
I recently picked up this amp. I can't seem to find out much about it. Do any of you have any experience with this amp or other Olson products. I have put a request in a Sams for a schematic. Hopfuly the can come up with one. It's a nice looking piece. The output tubes are a Triode/Pentode 6BM8 which I thought would be fun to get to know.
Tom
Old 6th January 2010, 02:43 PM   #2
tubelab.com's Avatar
I worked as a service tech at an Olson store from 1970 through 1972. We were not able to get schematics or service manuals for many of our own products. I don't remember your specific amp, since the SS revolution had already occured by then. The store was next to the University of Miami so the customer based changed regularly and we never saw much broken stuff more than 4 years old.
Olson would send specs out to the major equipment manufacturers of the time and contract with the lowest cost vendor. Many of the tube era amps were made by Kenwood and were very similar to a Kenwood or Trio amp made at the same time.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 6th January 2010, 03:34 PM   #3
Troncones's Avatar
Thank you. At a glance circuts and components seem to be fairly common. The one part that concerns me is I might need a new tone pot. This is a dual pot with 25K and 250K. Do you have any idea where I might fine one?
Thanks again.
Old 22nd July 2010, 12:05 AM   #4
Default Olson Model AM-158 Schematic
I stumbled on your post regarding the Olson AM-158. I happen to have a schematic diagram of this unit. Let me know if you still need a copy. If so, I'll scan and email it.
Old 25th January 2012, 10:18 PM   #5
John L is offline John L  United States
John L's Avatar
If you could afford to send me a copy of the schematic, and any other information, I would appreciate it. I too have one of these units that could use some TLC.
Thanks.
Lynn Olson Raven Question zelter Tubes / Valves 17 7th February 2009 09:20 PM
Precision Devices PD.158 Xmax? buggsson Subwoofers 6 20th May 2008 06:55 AM
Olson S-311 huymdt Multi-Way 9 6th September 2006 03:41 AM
Ariel by Lynn Olson- How good are they really? Samuel Jayaraj Multi-Way 4 23rd November 2003 09:20 AM
FS: Ariels - Lynn Olson design bbaker6212 Swap Meet 3 2nd October 2002 05:18 AM
Page generated in 0.07871 seconds (74.34% PHP - 25.66% MySQL) with 10 queries
