diyAudio Sponsor
Old 29th May 2003, 06:02 PM   #1
karma is offline karma  Canada
karma's Avatar
Arrow 5687 Line Stage
http://www.netaxs.com/~vkalia/5687.html
Old 29th May 2003, 06:56 PM   #2
analog_sa's Avatar
Nice line stage. If i had to listen to it, i'd probably use a single half per channel and plate chokes, but it probably sounds ok as is. Some people don't like the 5687 particularly as it doesn't sound quite 'tubey', if anything it reminds me of a very high quality opamp, one i can comfortably live with. Hopefully next century's opamps will be as good
Old 29th May 2003, 07:09 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Peter,
Have you applied to that Cryo treatment program?
Or on HGH pills perhaps?
Not that I don't hope we all make it to 2100.
Frank
Old 29th May 2003, 08:18 PM   #4
karma's Avatar
im just posting a link for people that like it i for one am not a big fan. i tryed it sound all right. but i have had better
Old 29th May 2003, 09:32 PM   #5
analog_sa's Avatar
Cryo treatment? I need to talk nicely to the guy who treated my cables.
Old 29th May 2003, 09:37 PM   #6
fdegrove's Avatar
Frank
Old 3rd June 2003, 07:33 AM   #7
binatang's Avatar
You can aso try this 5687 line stage found at www.diyparadise.com
http://www.diyparadise.com/simplepreamp2.html
Built it & it sounds great!
Old 3rd June 2003, 01:06 PM   #8
Joel is offline Joel  United States
Joel's Avatar
Originally posted by binatang
...Built it and it sounds great!
Hi Bintang,
What is the input impedance of the amp you're using with this? The Zo of the preamp is very high.
Also, have you had any longevity problems with placing a 100uF cap after the poor little 6X4?
Old 3rd June 2003, 01:31 PM   #9
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Originally posted by Joel
snip..
Joel,
Interesting point. I saw your message and thought "yup, too much". But then I started to think some more:
The rectifier manufacturer gives a max cap value, but this must be for maximum current, and it probably assumes a small series resistance. (Windings).
In a real circuit - especially a preamp, the current will be much less than max. This means that the rectifier doesn't have to work so hard to top-up that resovour cap. Also, this could be a case of "the smaller the mains transformer the better". Any secondary winding resistance is effectively in series with the cap.
So, maybe there are cases when you can stretch the rules a bit.
Old 3rd June 2003, 02:36 PM   #10
analog_sa's Avatar
Default Am i looking at the same circuit?
The power supply i saw is choke input so the value of the cap is not critical at all. Are we talking of the same circuit? The databooks always give max value for cap input.
Output impedance too high? 1.6k is not that bad.
cheers
peter
5687 fully balanced line stage cedus Tubes / Valves 14 24th July 2009 01:28 PM
5687 line stage costa23 Tubes / Valves 35 10th August 2008 09:53 AM
5687 as a single stage SE amp simonov Tubes / Valves 4 15th November 2006 09:26 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
5687 line amp with 0D3 regulator Original Burnedfingers Tubes / Valves 27 7th August 2003 01:51 PM
Page generated in 0.09734 seconds (77.87% PHP - 22.13% MySQL) with 10 queries
