diyAudio Sponsor
Old 2nd January 2010, 07:45 PM   #1
martyh is offline martyh  United States
Default Will this supply work?
Nothing left but final assembly on the 26 pre so it is time to start thinking about the amp it will drive. I’m considering all transformer coupled diff 6CG7 driving 6b4Gs. Since the interstage I have is sensitive to dc imbalance I want to independently bias the grids of the driver stage through the split secondary of the input transformer. I will also do the same thing for the B4Gs
I would also like to use a depletion mode mosfet as a current sink on the tail to force ac balance. So I need a negative voltage for the bottom of the CCS and 2x -35 to -70V 2x -6 to -10v
Modeling the supply as positive with the mess of 50K pots at the end as a single 50K resistor I get 21mV ripple at the 70v tap and 701uV ripple at the bias resistor.
Thanks,
Marty
Old 2nd January 2010, 07:57 PM   #2
The amp design as it is FWIW
Thanks again,
Marty
Old 2nd January 2010, 10:00 PM   #3
Cede is offline Cede  Canada
Send a message via ICQ to Cede Send a message via MSN to Cede Send a message via Skype™ to Cede
Rapid answer: you'll run into troubles!
One of your 330uF is directly tied to AC ! Unless you're planning to have fireworks, I'll try to avoid that
Other than that why use double choke ?
A simple one should be enough to my knowledge.
Old 2nd January 2010, 11:24 PM   #4
Voltage doubler constructed wrong way. Choke don't needed at all.
Old 3rd January 2010, 12:39 AM   #5
Thanks for the replies
Could someone please help me to understand what is wrong with the doubler circuit?
It is just a standard full wave doubler with the diodes flipped which I assumed I needed to do to get a negative voltage. I included the choke only to block any HF noise on the supply and used common mode because they are small and inexpensive.
Thanks again,
Marty
Old 3rd January 2010, 12:52 AM   #6
Oops,
Found it I think ….
Now hopefully the capacitor won’t blow up. Is this better?
Old 3rd January 2010, 12:56 AM   #7
llwhtt is offline llwhtt  United States
The lower lead from the 33VAC source is correct. The upper lead needs to go thru a diode to function. Check out the power supply for H-K Citation Two, reverse the diode and capacitor directions and you'll have what you think you have now.
Craig
Old 3rd January 2010, 12:58 AM   #8
You figured it out, good. As soon as my reply posted your correction came up.
Craig
Old 3rd January 2010, 01:01 AM   #9
Martyh yep it's better for the diodes
But for the choke, it looks like a choke to be used for main filtering.
Inductance looks like it has a too little value.
Old 3rd January 2010, 01:13 AM   #10
An easy way to figure out the Henries needed is to divide the load resistance by 1200. Example, 400 VDC@20ma. 400 divided by .02 is 20KOhms. 20K divided by 1200 is 16.66666666666666666666H. This mainly works for a constant load. Also if you notice the smaller the load the more Henries needed.
Craig
LM3886 Power Supply Modification - Might Work? mattthegamer463 Chip Amps 21 2nd July 2010 05:23 PM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
Great bench supply for tube work. gearheaddruid Tubes / Valves 25 21st August 2007 10:54 AM
Will This Supply Work With UCD180 valveitude Class D 23 27th April 2007 12:11 AM
Page generated in 0.09379 seconds (77.78% PHP - 22.22% MySQL) with 11 queries
