Plate chokes
Plate chokes
Old 31st December 2009, 04:46 PM   #11
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by SY View Post
For me, I would never use a plate choke unless I absolutely needed the swing- they're large, expensive, and subject to all sorts of unpleasant non-ideal behavior.
Especially with a high Rp tube. I recently tried 150H Hammonds on 6FY7 small triode sections (Rp ~ 30k) in a circuit with marginal B+, hoping for more plate voltage. Never made it off the bench, way too much distortion. No free lunch.
Ears aren't microphones.
Old 31st December 2009, 04:59 PM   #12
kevinkr's Avatar
Plate chokes
Use a good plate choke and a low rp triode like the 5842 or triode connected D3A (or other high transconductance pentode) and it is another story altogether.
I wouldn't select a tube with an rp of over 8K with this approach, and considerably lower is better.
That said I use this configuration for output stage drivers where the swing is an asset.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 31st December 2009, 05:14 PM   #13
On Hiatus
SY's Avatar
Plate chokes
Agree with both comments. High rp demands high inductance, and high inductance means highly non-ideal. But again, unless I needed the swing, I'd use a good CCS every time.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 31st December 2009, 05:43 PM   #14
tvrgeek is offline tvrgeek  United States
Red Light District Amp. Very good reading. Thanks.
Old 31st December 2009, 05:45 PM   #15
rdf's Avatar
... I'd use a good CCS every time.
CCS'd long tail pair, no silicon-love option this round.
Hi Kevin. I hoped at ~1.3 ma plate current and 8 ma chokes, maybe 40 v p-p swing I could make a run with the Hammonds but the explosion of harmonics was truly an impressive thing. They work a pip moved to B+ filtering duty though.
Old 31st December 2009, 10:58 PM   #16
kevinkr's Avatar
Plate chokes
I probably should too, in this case though I do need the swing..
Happy New Year!
Plate chokesHide this!Advertise here!
UTC CG-52AX - use as plate chokes? rongon Tubes / Valves 3 22nd August 2009 07:11 AM
Magnequest EXO-99 600H/150H Plate Load Chokes cm7 Swap Meet 6 18th July 2009 01:54 AM
Plate chokes & Power chokes JC951t Tubes / Valves 3 19th October 2006 03:18 PM
Help with plate chokes Burnedfingers Tubes / Valves 32 11th September 2003 01:01 AM
