Old 29th May 2003, 02:58 AM   #1
newguy is offline newguy  United States
Default How to add an HT bypass?
Very basic question...
I just got a tube linestage kit (Bottlehead Foreplay), and would like to modify it to have a home theater bypass: i.e. flip a switch on the chassis and completely bypass the linestage circuits.
Would something as simple as the attached work?
Any help would be tremendously appreciated!
Old 29th May 2003, 07:51 AM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Don't see why not.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th May 2003, 08:48 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Just make sure the switch costs at least as much as the preamp, and has rhodium-plated contacts as a bare minimum!! Don't forget to have it made from hepta-laminated (lucky 7's) silver, copper and gold of only the purest (5-nines minimum (99.999% pure)), most oxygen-free metal possible, and DON'T USE LEADED SOLDER TO MAKE THE CONNECTIONS, use the same grade silver as above, cast in place, to attach to the superconductor wires (what, don't tell me you don't have a supply of liquid nitrogen around!).
Tim
Seven Transistor Labs
Projects and Resources
Old 29th May 2003, 09:10 AM   #4
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Why bypass the linestage? Surely you want nice glowing valves while watching your DVDs????
Old 29th May 2003, 10:45 AM   #5
Brett's Avatar
Why not add the switch in the output, running the HT to there? Otherwise I'd use a DPDT where you have the switch now, shorting the intput to the FP (lower noise etc)
Old 29th May 2003, 04:09 PM   #6
(sorry if this appears twice - my prior attempt to post it didn't work because the file was too large)
Brett: Thanks for the suggestion! You're totally right, I should put the switch at the output.
If the FP is accidently turned on with the bypass engaged, is that dangerous? Is it bad to have an open circuit at the output?
Unless you see anything wronge I'll use the attached, with a dpdt on-none-on before the rca out.
Old 29th May 2003, 09:14 PM   #7
diyAudio Senior Member
fdegrove's Avatar
Default A LITTLE FOREPLAY NEVER HURT ANYONE...
No...but: make sure there's a bleeder resistor behind the last coupling cap so no D.C. voltage can develop at the output.
In which case you can even have the FP on in case you want it to warm up for later use while you're watching a DVD or whatever.
Frank
Old 29th May 2003, 09:30 PM   #8
If I remember right, the FP circuit has a 470K resistor to ground after the coupling cap.
I'm not sure how the first schematic would work. If he switches at the input, then won't he end up with the amp's input impedance and the FP's output impedance in parallel? So his HT source will be driving a much lower impedance. Or is that not how it would work?
Old 29th May 2003, 09:33 PM   #9
The other option is to use one of the inputs and add padding resistors to it so you end up with unity gain, or close to it. That way the FP will still be in the circuit, but it won't affect the volume of the front L and R channels (or at least, not too much). Of course, if you don't want the FP's sound in the picture, then you do need a bypass, that depends upon how picky you are about your HT sound.
Edit: I don't know if padding resistors would work, but I'm sure there are ways to make one of the inputs be "unity gain".
Old 29th May 2003, 09:35 PM   #10
fdegrove's Avatar
Both would work but the second one has a higher input impedance.
Even if the preamp is on, it isn't actively used but bypassed.
In which case it doesn't have an influence.
Assuming the input impedance at the front is a 100K...no big deal really.
Frank
OPA2132 bypass Radian Chip Amps 61 25th October 2009 12:29 PM
BG bypass MikeFarad Parts 1 30th July 2007 11:30 AM
Bypass cap on UcD 180? RogerWilco Class D 19 26th July 2005 03:35 AM
Bypass caps Praise! Parts 1 9th April 2004 01:28 AM
preferred bypass nosegoblin Chip Amps 5 30th January 2004 08:23 PM
Copyright ©1999-2013 diyAudio
