| diyAudio Sponsor | ||
I heard that 12E1 had the best linearity among indirectly-heated valves, when being connected as triode. So I plan to build a PP with triode-connected 12E1s.
Is there any tested schematic to follow? Or any recommendations based upon real experiences? Thanks in advance. |
#2 |
You could (and should) buy the book: "Valve Amplifiers, 3rd Edition" (Morgan Jones) I also highly recommend his book: "Building Valve Amplifiers" Both are highly informative, and entertaining.
www.kta-hifi.net |
#3 |
Anybody can offer further help?
#4 | ||
below URL. http://www.audiopro.co.jp/kairozu/ap919bk.jpg This amplifier is a product of Audio Senka in Japan. This schematic is derived from QUAD-II. I believe this amplifier is well tested for a selling product. Quote:
better linearity than 12E1. Please refer to the attached photo. GU-50(T) has higher plate impedance than 12E1. If two tubes of GU-50 are paralleled, the merged plate impedance is close to 12E1. |
#5 |
The first schematic came from a british tubeseller with a large inventory of 12E1 tubes.
S11E12 is equivalent with 12E1, so you can also google on that tube. |
#6 |
Schematic of SE and SEPP classA amps.
#7 |
12e1 in se
#8 |
Thank all above for the kind assistance.
In fact, FU50 is not as linear as 12E1 when being connected as triode. Moreover, generally speaking, tubes of Russian breed will produce coarser sound than those with British breed. I will test the 12E1 triode PP schematic. But as first I will try to apply 400V to g2 of 12E1, though the theoretic tolerance is 300V at most, to check its stability in such working conditions. |
#9 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#10 |
Well. That's quite true. Usually the tubes from Western Europe will produce more smooth and sweeter sound than those from USA, Eastern Europe and USSR (Russia). This phenomenon is called as "Capitalist tubes better perform than Socialist tubes".
Go back to 12E1. According to test, in SE Triode mode, if being applied 360V plate voltage, this tube will produce 8W with 7% THD, mainly even order. And if being applied 420V plate voltage, this tube will produce 11W with 7% THD, mainly even order. This means that this tube has great potential for triode PP application, as even order distortions can be cancelled in PP applications. |
| EL84 Triode PP Design | sorenj07 | Tubes / Valves | 23 | 19th December 2007 05:01 AM |
| KT88 PP suggestion | jarthel | Tubes / Valves | 13 | 27th June 2007 02:10 AM |
| Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? | ray_moth | Tubes / Valves | 4 | 23rd February 2007 12:22 PM |
| PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode | percy | Tubes / Valves | 23 | 22nd January 2007 12:36 AM |
| Page generated in 0.13239 seconds (80.84% PHP - 19.16% MySQL) with 11 queries |
