#11 |
I check and see that OPA1612 is only a SMD version. To use it we need an adapter.
#12 |
Banned
Yes...it's worth it! My absolute favorites with the CS4398 have been: OPA1611, LT1028ACN8, and LME49720HA. In other words, the most genuinely transparent (though each different from the others) opamps that I've tried so far.
#13 |
Andrea,
I have the following OPAMPS in front of me, and more around here somewhere...(some are garbage/singles or combination of both) TL072CP RC4558N OPA627AU LM6172IN OPA2134PA LME49710NA OPA2227PA LT1364 NE5532N LM4562 The LM4562 is my favorite so far... Gabriel, I will try and download the Sony Test CD and get that aoutput voltage to you...
All right, but apart from the sanitation, medicine, education, wine, public order, irrigation, roads, the fresh water system and public health, what have the Romans ever done for us? Life of Brian |
#14 |
Banned
I'm not surprised...and as I said the LM4562 goes well with the CS4398.
That said, personally I wasn't satisfied with the LM4562NA. I really preferred the LME49720HA to it, that's why I suggested that you try the LM4562HA. |
#15 |
What kind of B+ are you running and what are specifics on your PSU?
Thanks! |
#16 |
why not tranformer couple. I used sowters. all opamps removed.
#17 |
Banned
Why ten times more distortion (if not more) would be so desirable?
![]() With opamps, it depends on the opamps...really. |
#18 |
Banned
In this kit I'd also bypass the 4 green Nichicon Muse between DAC and opamp with something like Wima .1uF 250V MKS4, for instance (for size).
#19 |
I did change LM4562NA with LM4562HA (metal can) last week, the sound seems better than 4562NA but I haven't check that further since my maggie loudspeaker hitted by DC current comes from my friend stuppid tube pre-amp..
1 thing I noticed is 4562HA run much hotter than 4562NA so I have to put cooling fin around the 4562HA |
#20 | |
Banned
| Aikido 6SN7 input 5687 output | eeyore | Tubes / Valves | 2 | 27th March 2009 09:17 PM |
| 16SL7+6SN7 Aikido | regal | Tubes / Valves | 4 | 7th July 2008 07:46 AM |
| Tube rectified LC PS for 6SN7 Aikido - choke DCR question | LowRedMoon | Tubes / Valves | 3 | 20th June 2008 05:20 AM |
| tube hum in a 6SN7 Aikido - is this weird? | cbutterworth | Tubes / Valves | 16 | 12th March 2007 04:52 PM |
| aikido 12b4 input 6sn7 output??? | cbutterworth | Tubes / Valves | 1 | 26th October 2006 11:06 PM |
