| diyAudio Sponsor | ||
Hey guys, question. I searched for it and couldn't find anything so apologies if this is a stupid question.
Basically I'm interested in increasing the power output of Pete Millett's Engineer's Amplifier from ~20 Watts to 40-50 Watts to drive a set of 4-5 ohm Magnepan MMGs. I'm rather new to the tube world (solid state guy mostly) and according to Pete, I need to raise the B+ and lower the plate to plate load impedance. What I'm looking for is how to do this correctly (I can probably figure this out, but more than likely to the demise of my speakers, the amplifier, several otherwise perfectly usable tubes, and likely my source too). So what wisdom can you send my way in accomplishing this task, and what things I might need to be concerned about both in increasing the output power (while minimizing the distortion and noise as much as possible) and also driving a 4 ohm speaker with a tube amp. Thanks for the help guys |
#2 |
First, realize that the power difference you're talking about represents only about 3dB or so difference in loudness- that's noticeable but not exactly profound.
In any case, what you'll need to do is use sweep tubes with higher plate dissipation (any of the tubes in the 30W class should work OK). Then increase plate voltage and reduce plate-to-plate load impedance. You could accomplish the latter by connecting your 4R speaker across the 8R tap. I've been experimenting down the same lines- I changed the output tubes to 6LF6, increased the B+ to 450V, and reduced the p-p load to 4k. That got me a solid 60W. Next step is to drop the load to 1250R and increase the B+ to 600V...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 | |
#4 | ||
Posted new P-P power amp design It has been discussed pretty good there. There are 192 posts. Several posters discuss their methods for obtaining a bit more power. My "red board" now makes 125 watts per channel, and I am not done with it. 150 WPC should be easy, maybe more. Post #149 demonstrates that the little 6JN6's respond well to a lower load impedance and more voltage. I used a 6600 ohm output transformer because I have them. You will get 50 WPC with a 450 volt power supply, and more power with more voltage. In post #168 I plugged in some bigger tubes and tested further. I used 6HF5's (again because I have some) and obtained 125 WPC with a 3300 ohm load and a 520 volt power supply. More testing will happen, but right now the amp and I are 1200 miles apart. I left the power supply components off of my board and used external supplies for all testing. I do this with all of my amp designs (or major modifications). Once I decide on what voltages and currents I want in the final amplifier I will either modify the on board supply or design an off board supply. As with any amplifier (tube or solid state) the further you deviate from the original designers intended power output, the more modifications are required. As I found out (and I know better) you need higher voltage electrolytics to go much beyond 50 WPC. Quote:
Picture of board in post #170
Too much power is almost enough! Turn it up till it explodes - then back up just a little. Last edited by tubelab.com; 28th December 2009 at 02:33 AM. |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| increasing current output | xplod1236 | Solid State | 7 | 27th March 2004 06:24 AM |
| Increasing Power Output of a Car amplifier | Dj BASS AMP | Solid State | 5 | 5th October 2002 11:37 PM |
| Increasing power output of Rod Elliot amp | mjd_tech | Solid State | 1 | 2nd April 2002 09:29 PM |
| Increasing output channels of preamp. | hugobross | Solid State | 19 | 6th February 2002 04:13 PM |
| Page generated in 0.09379 seconds (74.60% PHP - 25.40% MySQL) with 11 queries |
