diyAudio Sponsor
Old 26th December 2009, 12:49 AM   #1
Zekk is offline Zekk  Singapore
Default Tricked On Ebay!
Hi Folks!
Following is my recent Ebay encounter :
Bait: " Old Tube Amp 6973 ".
Looks like an Ampex 6973 Stereo .
The 5U4 and 2x 6AN8 were not mentioned at all!
"Buy-It-Now" .. Do not wish to miss the boat .. so ...... jumped in!
Upon receiving, wiring not in order of an 6973 circuitry.
Pin #1 connected to B+, #2 and #8 not connected!?
There's no marking what so ever on the chassis. Doubted the quad RCA 6973 black plates meant for this amp!
Initially felt cheated but after re-accessing what I've on hand, beefy irons, nicely built chassis, not too bad ya!?
Making the best out of this prevailing situation, I've decided to build a clone copy of the Ampex 6973 15watts amp on the existing chassis.
Problem is, are the OPT with inscription TR 159-831-839, compatible or not? Quite heavy and weights 1.8kg each.
Have 5 wires sticking out, 2x for spks, one for B+, and the other 2 individually connected to plates. From the schematic, needs a connection for the screen.
How do you figure out an unknown OPT?
PLEASE HELP!!
Thanking all for looking & Wishing all a happy holiday,
Cheers!
Zekk
Old 26th December 2009, 02:07 AM   #2
wa2ise is offline wa2ise  United States
wa2ise's Avatar
Zekk
One way is to figure out the turns ratio. Apply some low AC voltage, say 12V AC to the primary. Using an AC voltmeter that can measure mV AC, see what you get on the secondary. Once you have that, divide the voltage you applied to the primary to what you measured on the secondary. That gives you the turns ratio. Impedance ratio is turns ratio squared. If 8 ohm load on the secondary gets you twice too much primary impedance, use 4 ohm speakers. This will, IIRC, double the bass response at the cost of the treble end.
Old 26th December 2009, 02:33 AM   #3
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Why the title " Tricked on Ebay"?
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 26th December 2009, 02:40 AM   #4
Tom Bavis's Avatar
Pin 1 is the screen, could be connected to B+ or the OPT tap. 2 and 8 would not be connected. The stereo Ampex amp I've seen has 7199 drivers and a solid state rectifier - perhaps this is an earlier one?
Old 26th December 2009, 12:59 PM   #5
Zekk,
I think that Tom may be on to something. Using a 6AN8 in Scott/Dyna style circuitry is common enough and the type is available, while the 7199 is fast becoming "unobtainium".
You indicate that the "iron" lacks UL taps. So, triode and full pentode modes are your choices. A glance at the 6973 data sheet shows the type to be "12" W. that uses the same sort of trafos the EL84 and 6V6 use. 6 WPC is a realistic expectation for triode mode.
Trace the circuit out and post your findings.
Eli D.
Old 27th December 2009, 03:59 AM   #6
wa2ise
Thanks for that invaluable guidance to a newbie like myself.
poynton
.... that's my feeling!
Eli Duttman
I've cleaned out the chassis to bare metal. A postmortem is not possible.
Wish to start anew.
The two existing Ampex 6973 schematics available runs in UL mode.
When switching over to triode, do I needs any modification besides connecting plate to screen via a 100R resistor ?
Or perhaps, someone out there have a similliar 6973 circuit to share?
Read so much favourable comments on various forums, that I'm obsess to building one for a listenning experience .
Hey Folks ... keep them coming ... THANKS!
Zekk
Old 27th December 2009, 02:26 PM   #7
Zekk,
Does it have to be an Ampex circuit? You have the makings of an "El Cheapo" variant. Switch to SS rectified B+ and use the 5 VAC winding to energize a voltage multiplier to get B-.
FWIW, I'd use 1 KOhm parts to tie g2 to the plate. Using 100 Ω parts may not provide sufficient protection against excessive g2 current.
Eli D.
Old 27th December 2009, 09:59 PM   #8
I don't quite understand how you were tricked on ebay. Isn't it your responsibility to ask any and all questions that you need answered in order to make an informed decision to buy? Sounds like it was still worth the money.
Old 27th December 2009, 10:48 PM   #9
vinylkid58's Avatar
I found that out the hard way.
Jeff
Old 27th December 2009, 11:04 PM   #10
Default ....6973 For A Listenning Experience!
Zekk,
Looks interesting but can 6AQ5 be sub with 6973?
As mentioned earlier, wish to make full use of componants in hand.
Eli .... appreciated your contribution.
Take A Look At These On Ebay sdclc126 Multi-Way 8 9th January 2009 05:06 PM
:)))) on eBay!!! LOOK!!!! :)))) cartman Swap Meet 14 9th March 2006 11:43 PM
eBay Prune Tubes / Valves 2 25th September 2004 07:16 AM
Page generated in 0.11321 seconds (88.60% PHP - 11.40% MySQL) with 11 queries
