| diyAudio Sponsor | ||
Something tells me that bob carver doesn't pop up in the tube forum all that much... however, I found a schematic for an all-tube design with his name on it. It looks appropriately complicated and, well, Carver-ish. I am rather intrigued and was wondering if anyone knew anything about it, as my googling has failed to turn anything up. There should be a schematic at schematicheaven.com in the post 70's section.
#2 |
If it's the one with 15 KT-88's, the schematic was published in an early issue of Glass Audio.
Hey is for horses. |
#3 | |
Bob Carver left Phase Linear to start Carver Audio. His first product was the M-400 "Magnetic Field Amplifier". I still have mine, and I have a schematic somewhere. There is nothing "magnetic" about it. It is a class G amplifier with 3 different supply rails and 3 sets of output transistors per channel. It uses a crude SMPS with a 60 HZ switching frequency. Most experienced exploded triacs. Bob was famous for talking up his amps, and talking down the tube amps of the day. He did some demonstrations where he claimed that one of his big SS power amps could be made to sound just like a tube amp with the addition of a magic device between the amp and the speaker (a big resistor). A small but fanatical piece of the high end audio market wasn't buying into it, so Mr. Carver decided to make the mother of all tube amps. The SILVER SEVEN was born. Googleing will find some info. Apparently there were several different versions of the Silver Seven. I have never seen one myself since they were way out of my price range. I had a friend who was a Carver dealer and he refused to go near tube equipment. He did however talk me into buying the M-400. His story was that the early Silver Sevens had heat related failure issues. Well He sold 12 of the M-400's. They did not have a power switch, and the manual strongly urged that the power cord be plugged directly into a dedicated outlet. I ignored that advice and plugged it into the switched outlet on a Phase Linear 4000 preamp (another Carver creation). My M-400 is the only one of the 12 that is still working. The others all had their triacs exploded by lightning.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
So is/was the M-400 worth it? That was the tiny 200 watt Cube amp, correct? I remember a friend having one and it was atrocious. Thin, no soundstage and lifeless...I remember a Electrical Engineering friend saying it was a glorified automobile amp.
I credit my Carver TFM-15 amp and matching CT-6 Preamp for getting me OUT of audio for 10 years. I had a bug up my you know what to replace my beloved Luxman receiver with this Carver amp/preamp jobbie after graduating college. Spent my first month's salary on it too...I totally hated that system and wished I never got rid of that Luxman. My B&W DM220i sounded awful. I long considered Carver to be the Bose of Amplifiers. A friend of mine absolutely loves his Sunfire amps...don't know anything about the new Carver stuff....but I am looking forward to having my friend over to check out my Krell KSA Clone soon.
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V Last edited by john65b; 24th December 2009 at 03:48 AM. |
#5 |
Ahhh... the amp is listed under "Super Seven" on a website. But my god... the OT in that amp is comical.
I have an M-400 in my dorm room, currently being a paperweight/doorstop. When it works, its decent with good speakers. The filter caps decided to call it a day and completely burned through the board... alas... "forcing" me to get 5 Marantz monoblocks. |
#6 |
hey-Hey!!!,
Resurrecting a Carver PM900 was the start of my re-entry into Hi-Fi. It suffered a driver transistor failure that cascaded into the power supply(s). Rebuilt the board, replaced the caps and then had to find that failed transistor... cheers, Douglas
the Tnuctipun will return |
#7 |
I've had a TFM-55 for a couple of years now, totally recapped it and modified it with some Allen B resistors, better trim pots, transistors etc.
I love it. Drives my Klipsh speakers brilliantly with so much headroom. BTW I'm driving the TFM-55 with my DIY tube preamps. It brought the Carver design to life. But one of these days I will build tube monblocks. Just a matter of transformers. Can't buy them here ![]() Last year Bob sent me the schematics of one of his one time signed tube amps sold on ebay recently. If I remember correctly it was 2 monoblocks with 8 KT88's per channel. standard gain stage with phase inverters and some little so called tricks in his circuitry. |
#8 | |
I got a job at the Motorola plant (where I still work) in 1973. There was a group of "audiophiles" working there who had systems costing big money. Most of them laughed at my junk but a few who took the time to actually listen, wondered how I got it to sound so good. I still had my "junk system" in the early 80's. All of the tube stuff that I was building was MI equipment, since I actually liked my stereo stuff. One of the audio gurus had made a deal with the Carver distributor. If he could pre - sell 10 of those new fangled M-400 cubes, he could become a Carver dealer. I agreed to buy one of the cubes and his old Phase Linear preamp for less than the local high end store wanted for the cube alone. I got the "high end stuff", hooked it up and wasn't too impressed. It just didn't sound realistic, and there was this annoying ticking sound. It was loud, really loud, but to me that was its only attribute. Yes, Carvers little cube claimed 200 watts per channel. The manual warned sternly that attempting to actually measure the output power would blow up the amp and void the warantee, so I never did. They also warned against using it for a guitar amp, which I did do, and it worked good. Regardless of the actual power output it wound up blowing my University Labs speakers. The Phase Linear started getting erratic (worn pots, bad caps) so the whole thing went into the warehouse where it still sits. I used a yard sale Fisher tube receiver for a few years until I built my own system. The M-400 that I had was one of the very first units. It was a silver (or light gold anodized) box. The later units were black. There was no power switch so the unit stayed on all the time. The power supply used a triac that pulsed on briefly at low output powers. The pulse resulted in an audible tick from the amplifier itself. The large current pulse would make its way to the speakers if the system wasn't carefully set up. The current pulse was large enough to blow the line fuse occasionally. Against advice in the manual I put a slo-blo fuse in mine. Again against advice in the manual I plugged mine into the switched outlet in the preamp since I don't like leaving things powered up when I am not home. The power grid in Florida hits multiple lightning hits a day in the summer. All of the other units thas were bought with mine died as a result of lightning strikes. Carver refused warantee service on these units and wouldn't sell us triacs either. They claimed that a bunch of electrical engineers weren't qualified to service these units. The guy who got the units eventually got the service manual and a bunch of triacs from the distributor. He even managed to secure a "one time upgrade deal" for all of the original purchasers. He got a rack mounted 1.5 killowatt monster, but I decided to "just say no" and stick with the Fisher. I still have the Carver, the Phase Linear, both Voxson receivers, and the Fisher receiver. The Carver and the Fisher still worked the last time I tried them. I wanted to hook up the Voxsons to see if they really did sound as good as I remember, but neither one worked. I have no desire to hook the Carver back up except maybe as a really loud guitar amp (until it blows up). The Phase Linear preamp did have a dynamic range expander and an "auto correlator" that did a good job of adding some life to dead (over compressed) recordings or FM radio, but it would require a major rebuild.
#9 |
"Last year Bob sent me the schematics of one of his one time signed tube amps sold on ebay recently. ------ standard gain stage with phase inverters and some little so called tricks in his circuitry. "
Like this? What if O.H. Schade had MOSFETs?
Ohms Law V = I R |
#10 | |
Dave |
| audio nirvana super 10 or super 12 | tonytex | Full Range | 11 | 4th September 2011 10:55 PM |
| Nirvana super 8 and cast super 8 how do they compare to 206E? | freddi | Full Range | 4 | 22nd October 2010 02:29 AM |
| FS: SUPER CD PRO KIT with SUPER SHOCKPROOF | bbp | Swap Meet | 5 | 17th April 2009 05:09 AM |
| Carver Sunfire Super Junior 8 - Who makes the subwoofer in the cabinet | tomtomjr | Subwoofers | 13 | 8th December 2008 06:46 AM |
| super nice carver home stereo amp on ebay | scottericsonon | Swap Meet | 0 | 19th November 2007 04:38 AM |
| Page generated in 0.14146 seconds (84.12% PHP - 15.88% MySQL) with 10 queries |
