| diyAudio Sponsor | ||
I have found some Mullard M-series tube, M8136, M8137 and M8098 in my garbage
They are equivalent of ECC82 and ECC83 but I can't find online the original datasheet of these tube. I only know they are a special quality of these tubes. The M8098 look like a regulator tube, at which tension? Any help? |
#2 |
M8098 is an 85V neon reference and looks very similar to 85A2.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
The 85A2 is a great reference imho...
www.kta-hifi.net |
#4 |
Thanks!!
And about the datasheet of these Mullard Mseries tube? |
#5 | |
M8137 and M8136 are direct equivalent to ECC83 and ECC82 M Series is Mullard military version having box type anode pale
| The Mullard 3-3 | atnaat | Tubes / Valves | 8 | 21st May 2009 01:54 AM |
| Mullard Articles | ray_moth | Tubes / Valves | 2 | 15th March 2009 02:18 AM |
| Anyone else have the new Mullard EL34's? | JayH3 | Tubes / Valves | 11 | 5th February 2009 11:12 AM |
| Mullard 3-3 | Bas Horneman | Tubes / Valves | 32 | 28th February 2003 04:38 PM |
| Mullard ECC83/M8137 | david3565 | Tubes / Valves | 0 | 16th December 2001 07:15 PM |
| Page generated in 0.08950 seconds (73.04% PHP - 26.96% MySQL) with 11 queries |
