diyAudio Sponsor
Old 17th December 2009, 03:57 AM   #1
Default ECL86/6GW8 Console opinions
Attached is a rough schematic of my old console amp that I use for my computer listening. It actually runs quite well after replacing the Cs and Rs and removing the tone control section (which was a convoluted arrangement in a feedback loop). Note there is no direct feedback loop now . I'm not going to push the envelope too much with this, as the tubes are almost unobtainable now.
The main reason for this message is to see if there are any glaring mistakes in the design (or my alterations to it; I don't have an original schematic).
Note that the triode section gets its anode supply from the pentode screen. Would there be any reason not to take them from the B+ point instead? It would make measuring screen and anode currents easier.
The output stage only runs 32mA anode current by my calculations of drop across the o/p trans. Sounds a bit low to me, but these are old tubes not NOS. I think it only gets to about 2W out into 8ohms before it starts to clip.
Thanks, Gary
Old 17th December 2009, 04:06 AM   #2
DougL is offline DougL  United States
The only thing I see is you left in the 330 pf cap that rolls of the high end to maintain feedback stability. You do not need it. Just adds to high frequency distortion would be my guess.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 17th December 2009, 04:34 AM   #3
Yes, I noticed that today when I was drawing this up. I guess I should have removed it as the response is down 3dB at 10kHz (and 100Hz which I blame more on the small o/p trannys)
Gary
Old 17th December 2009, 05:15 AM   #4
The front end and screen grids both benefit from being isolated from the B+.
You could add a separate RC for the front end if you want.
The 1 Meg pot may be contributing to the HF roll off as well. There is no real reason to use anything bigger than 100K. Having said that, the Dinaco ST 70 had a 250k grid leak because the pentode front end shielded the input from the miller capacitance. If I were a betting man the input triode is high mu, and has a high voltage gain. Sorry, too late at night to look it up. That virtual cap probably interacts with the pot to roll off the highs.
Another thought is to replace the RC on the input with an LED string that gives you about the same voltage drop. It will eliminate an RC time constant cheaply may be better than most caps.
You may be right about the LF roll off being due to the transformer. It's that or the cathode bypass caps.
HTH
Doug
Old 17th December 2009, 05:59 AM   #5
aardvarkash10's Avatar
what is the 47k res at the input doing?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 17th December 2009, 06:51 AM   #6
frugal-phile(tm)
planet10's Avatar
Every time someone says that i'm surprised... my stash of these keeps growing.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th December 2009, 05:52 PM   #7
That's a leftover from a divider network I thought I might need to match the computer output. It really doesn't do anything now.
Old 17th December 2009, 05:59 PM   #8
dave
Well, you can send some my way if you like
Seriously, the best price I have seen for these tubes NOS is about $18 USD each for an unnamed brand. None at any price available here in New Zealand.
If my tubes give out (I still have a couple of spare used ones), I'll rebuild the amp with ECC82/EL84 as there is room on the chassis.
Gary
Old 17th December 2009, 06:17 PM   #9
HTH
Doug
The pots were a leftover from the original console, as I didn't have a dual gang one to replace it. Might have to hunt down a lower value one.
I'm still trying to get my head around the LED cathode bias idea, it's something new to me. As the cathode DC point is only about 0.8v on the triode section, can I just stick an LED in there on its own and lose the R & C?
Actually, I measured both channels, and one cathode is 0.8v and one is 1v DC at idle, and the anode voltages are 140v and 113v so I guess one tube is down a bit. Would the LED help correct that?
I trained on radio valve gear for a year, but that was 35 years ago, and haven't done anything since with them until now, so I'm re-learning things from scratch
Old 17th December 2009, 06:57 PM   #10
Short answer, yes.
Longer answer is that you need to pick a diode with the right voltage drop for your circuit. IIRC, the infer-red LED drop about a volt. you could also use small signal diodes for lower voltage drops. The point is a diode has a low dynamic resistance and a fixed voltage drop and looks much like a RC from AC and DC perspective but much faster overload recovery / less memory and does not have the Dielectric absorption issues of a capacitor. Its a drop in, parts are inexpensive, and its worth a try at some point.
Doug
6gw8 /ECL86 El Cheapo modifications bbuz Tubes / Valves 13 24th June 2008 01:16 AM
Quick Ecl86/6gw8 Amp cammy666 Tubes / Valves 2 12th July 2007 02:48 AM
Substitute for 6gw8 in Heathkit aa-32 oldheathkitphil Tubes / Valves 3 22nd May 2007 11:20 PM
6L6 for a beginner, plus ECL86/6GW8 jsp Tubes / Valves 22 8th April 2007 10:09 PM
Help with 6GW8/ECL86 tubes?? fluckscapacitor Tubes / Valves 5 11th October 2005 02:46 AM
Page generated in 0.12575 seconds (80.62% PHP - 19.38% MySQL) with 11 queries
