| diyAudio Sponsor | ||
Hello all
Wanted to share this contact with all...these pepole will wind any size/type of transformer at reasonable cost...some companies will not wind you a 1000 watt output tx these guys will...allso winding for me at present 750ma 15 henry choke company is BLS Electronics...in co Durham UK Contact simon Williams...on tel no 01207 234 018 Email s.williams@btconnect.com |
#2 |
Can you please share info on types/specs/prices/core material, too? Thanks in advance?
#3 |
url=www.blselectronics.co.uk/
Click: BLS Electronics Ltd - Mains transformers, AC inductors, Switch mode power supply transformers, Custom mains transformers |
#4 |
hey just contact them...though for example...200 watt kt 88 transformer ultralinear was 120 pounds....Ian
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 05:17 AM |
| Transformer manufacturer suggestions | needlz | Chip Amps | 1 | 20th April 2005 07:50 PM |
| Page generated in 0.07428 seconds (70.58% PHP - 29.42% MySQL) with 10 queries |
