no resistor values........
Old 15th December 2009, 12:15 PM   #1
pointy is offline pointy  United Kingdom
pointy's Avatar
Default no resistor values........
Hi I'm back
As you may have heard I have been working on a switch able pre-amp project for some time now. And now I have reached the point where my memory starts to fail me. I have been planning to try some classic SS CCS circuits and be able to switch from one to the other so I can make a direct comparison between them.
The stumbling block(s) are that I have two schematics which I would very much like to try but some of the resistor values are not stated. I have a B+ voltage maximum of 275v and a current of 80ma but I will be installing potentiometers to bring these down further (between back to back transformers 12v for the B+).
1.Wavebourn pnp cascoded ccs (good at blocking AC)
2.Nelson Pass aleph mosfet + transistor (can be made to produce a bass dynamic)
Old 16th December 2009, 09:25 AM   #2
Arnulf is offline Arnulf  Europe
In both cases the current setting resistor (R1 in first picture and series combination of two resistors under that FET on the second picture) are calculated like this - I'll elaborate on right picture because left one is missing other key details (zener voltage):
dU = 0.65V (base-emitter voltage drop)
I = desired current that CCS supplies
R = dU / I
Collector resistor of right picture can be of just about any size that allows enough collector current to flow, 4.7K is just as good a choice as any.
Old 16th December 2009, 01:11 PM   #3
pointy's Avatar
thanks for your help........i make that about 40.5ohms for 16ma i will try a 50/50 split say 20ohms for the top resistor and 20ohms and a bit more on the tolerance band for the lower unless anyone can say better (ONLY AN EXAMPLE).
would a 1N5388B zener diode be over-kill for the diode i can only think that it maybe out of the range of the transistor base for ccs use.
Old 16th December 2009, 02:08 PM   #4
On Hiatus
SY's Avatar
BTW, lose the bypass cap across the LED- it's useless in that spot.
A MOSFET cascode using depletion mode FETs will outperform just about anything.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th December 2009, 02:22 PM   #5
pointy's Avatar
i hope it readable.........
Old 16th December 2009, 05:51 PM   #6
I'm not sure what author wanted to achieve there, but if it was me I'd use a single resistor and take output directly from the anode. You're losing some gain by splitting it in two, assuming the tube anode is biased exactly halfway into B+ in quiescent state.
Yes, it would be. Zener diode only dissipates as much current as you allow it to and in order for it to stabilize at its nominal voltage 1 mA is more than enough. R4 will be the element that dissipates vast majority of power lost there, you can use any 1/2W 5.6V zener or even LED if you want less noise and don't mind tinkering with precise resistor value (LEDs, unlike zeners, don't come preselected for specific voltage drop ...).
Oh and DN2540 is not an enhancement type MOSFET. If you want to use that you can lose majority of componets there, you only need one resistor to set the current.
Last edited by Arnulf; 16th December 2009 at 05:54 PM. Reason: Just noticed your new pic says DN2540 where enh-mode N channel should be
Old 16th December 2009, 07:35 PM   #7
pointy's Avatar
i can get these from cricklewood electronics............but they look a bit over-kill as well
Old 16th December 2009, 08:21 PM   #8
pointy's Avatar
the story so far........... i hope they don't mind me snipping up their pics
File Type: jpg wavebourn 1st ccs with some resistor valves.jpg (25.8 KB, 45 views)
Old 18th December 2009, 02:21 PM   #9
pointy's Avatar
After extensive research.............
Old 18th December 2009, 02:31 PM   #10
pointy's Avatar
sorry i've misplaced the decemal point .........for 6.5/A use 0.65/A
no resistor values........Hide this!Advertise here!
Resistor values Valvomaniac Tubes / Valves 5 27th April 2007 05:50 AM
Resistor Values For L Pad? kelticwizard Multi-Way 8 16th February 2006 02:41 AM
Resistor values Stocker Chip Amps 3 4th May 2004 04:10 PM
Resistor values? randytsuch Chip Amps 2 11th July 2003 02:08 AM
