diyAudio Sponsor
Old 14th December 2009, 08:08 PM   #1
gurley123's Avatar
Default Help please, Jolida 202a hum.
This may be futile but i need to give it a shot.
I need some help chasing down some hum in my amp. This hum appeared about three weeks ago in my up-to-now very quiet Jolida 202a. The hum appears to be independent of volume setting or source selection. It's fairly low level but loud enough for me to hear in the quieter passages of music. I've owned this amp for about 16 years now and this is the first bit of trouble I've had with it.
Right around the time the hum showed up, I had a power tube spark on me. I think I had let the bias drift to far and that is what caused the sparking. I had heard some static right before the sparks but I thought it was in the program I was watching(my amp is not in my line of sight.) After sparking, the tube still appeared to be sealed and after biasing behaved reasonably well (it was a little erratic but I kept the multimeter handy and checked it often) but the hum was now present. Four new tubes now and the hum is still there.
I have very little knowledge of tube amps other than what I have read (lethal voltages inside!!!, it might not be that hard to change it to triode, ect.) and I know that tracking down hum problems are tricky in the first place but I thought I would ask for some help here. Maybe there's a simple fix for it (I'm not holding my breath.) I would like to thank you in advance for just coming here and reading my post and will get the wife to bake you up some awesome cookies if you can help my exorcise my noisy demon.
Old 14th December 2009, 09:15 PM   #2
Dear gurley123,
May I ask your help.
I am new to the site and despite searching have failed to find.
How did you make your post?
Having given the details and asked the questions how did you post/get it put up on the site?
Sorry if am a burden but would be very greatful for your help.
In hopeful anticipation, thanks!
StephenJ
Old 24th January 2012, 05:29 PM   #3
Swap the Power Tube that sparked to the other channel. See if the hum moves with the tube. I had a defective 12AX7A, one filament was really bright. I had a hum that was uneffected by volume control so I figured the hum was getting picked up from the ac filament voltage. I moved the tube and the hum went with it. Now I have some vintage NOS preamp tubes on the way.
Old 1st February 2012, 08:14 PM   #4
did you noticed the thread is three years old?
Old 2nd February 2012, 12:58 AM   #5
lmao... Ok I guess someone can learn from the thread.
Amp trouble - infinity Kappa 202a silversweden Car Audio 48 9th February 2011 08:42 PM
jolida cdp issue Midnite Mick Digital Source 0 8th January 2007 03:26 AM
How to open an Infinity Kappa 202a amp? Compman55 Car Audio 10 22nd July 2006 05:48 AM
jolida Jd 100 gemballa Digital Source 0 1st June 2004 07:43 AM
Jolida-Shanling Facciadaprete Digital Source 3 10th May 2004 02:43 PM
Page generated in 0.08904 seconds (74.10% PHP - 25.90% MySQL) with 10 queries
