| diyAudio Sponsor | ||
#11 |
TM,
If you use any sort of choke I/P filtration, true or pseudo, you will have 2 big inductors on the topside of the chassis. Mount the toroidal power trafo on the underside of the top plate, where it can't be seen. An "acorn" nut makes things attractive, "upstairs". A very easy way to bring the B+ rail voltage down somewhat is employing a true choke I/P filter and FWCT rectification with a pair of damper diodes. ESRC is selling 19AU4s for $1 each. You'll have to buy 10 (big deal). Wire the heaters in series and energize them with an AnTek model AN-1236. The 1st inductor in a choke I/P filter gets the snot badly beaten out. HEFT is the order of the day. The 21 lb. Hammond model 193Q should do. "Ordinary" stuff is fine for the 2nd inductor.
Eli D. |
#12 |
hey-Hey!!!,
On the choke input choke, there are vintage swinger chokes to be had in the usual markets, but they're a bit rare. I've designed a swinger with standard E-I lams that should work well in this service w/o the nasty saturation buzz. The gap is a wedge, longer at one end of the E than the other to give a slow and gradual saturation of the core as flux( both AC and C ) increases. cheers, Douglas
the Tnuctipun will return |
#13 | |
#14 | |
That particular Hammond is *THAT* good. Totally put the brakes on building clones of the Peerless S-271-S I acquired and had torn down( shuddering while remembering the cost involved with that exercise ). cheers, Douglas
#15 |
hey-Hey!!!,
I'd also suggest a different circuit...but check out Dave's post here: Tube DIY Asylum - Hammond 1650R - Salectric - December 11, 2009 at 04:08:37 He's built an amp with them and could tell you how it worked for him. Straying from your current design is not what I am suggesting, at least not yet... cheers, Douglas
#16 | |
ok I'm in too, let's build the nicest KT88 PP around! Reread your first post and the goals for the project is quite similar for what I have lined out in my thoughts, even been thinking of mono-blocks here too! I didn't aim for so high power with these tubes though it's probably not impossible but I would like to not run them so hot, I guess I would be happy if I get even lowish 30-40 Watts but maybe 50 is quite a sensible compromise and it's just 1 dB here or there and isn't really hearable. Transformers, agree we should go for something good but as you also said within reasonable costs as some are very expensive, but still the transformer is a very big part of the sound quality so should be high on priority as it's something one doesnt swap out after the amp is built. I would prefer toroids through-out for several reasons because of the great bandwidth with toroids and that it's very easy to get (ironically though!) even with standard winding teqniques, the other reason is very low magnetic stray field meaning surrounding components will pick up less hum especially good thing in the power supply transformer but yet good magnetic connection between primary and secondary meaning less stray inductance especially important for the OPT. OTOH toroids doesn't have the "vintage sexiness" as ol' EI cores but square shaped cans can be found of course which is what I will go for if I use toroids. Found one supplier of toroidal OPT's Antek - Your reliable source of transformers, power supplies, and more. eBay Store - Antek inc: Transformers, Enclosures, Power Supply but they have very few models which is pity as they have a 70 Watt and 8 lb model which would have been on spot but it has a very low primary input impedance of around 2k and that's way too low I guess as I haven't seen anything near when it comes to KT88 PP amps, well I sent an e-mail inquiry about higher input impedance to them but just recently read from the very few post on DiyAudio regarding Antek that some have not had any good luck communicating with them. A Polish maker replied today they don't make output transformers, I truied to tell them I can give the winding specification but it seems the message didn't went through. Hammond 1650R was mentioned, of some reason I got a feeling Hammond is not the pick from the very little I have read, like this thread: Japan vs US output tx read post #15. The good part is I found out I can get these locally to a reasonable price, but would still like to get more FB on Hammonds. Douglas link looks promissing so will have an eye how that thread develops. Well, there's some food for thoughts for now, even if we wouldn't agree on all details I think we should still stick together and make it through, this is going to be a great thing and I think I won't build so many tube amps in my life(?) so this one is going to be something extra so I will for sure beside building an excellent amp also add som bling-bling as well to its aesthetical appeal. Oh, and don't worry about electronics/electricals and such things, I am a 'toob-noob' too but have some knowledge of electronics and I would be happy to give a helping hand as much as I can and I'm sure we will get lot more help from the forum members too. EDIT: oh, and for the record if I didn't say it Option 1 looks like a great base to build on and I'm sure we can eventually add some further goodies and improvements! Cheers Michael Last edited by Ultima Thule; 14th December 2009 at 03:30 PM. |
#17 |
#18 |
Here are the related threads if you want to read up.
Help modifiying schematic My new project, 2 x KT88 60W amp Help with amp layout After reading more, I would like to lower the B+ to the KT88's to 460V. Also, I think I'd rather stick with traditional vertical Trannies @ this time. As soon as at can get the Specs nailed, i'll purchase, or order custom from Electraprint. As to the PS, I'd really love to keep it straight foward, and simple. I.E. diode bridge, single choke, caps, and resistors. As long as it performs well, i don't want to get too involved here. I'd therefore like to size the PS trans, just right to achieve this. Ultima Thule, How do you feel about 460V? Last edited by TubeMack; 14th December 2009 at 11:45 PM. |
#19 |
TM,
For a PSU with CLC filtration, you will not get a better value than the AnTek model AN-4T360. The rail will be in the 450 to 475 V. range, which is just fine for KT88s. Be sure to use a CL150 inrush current limiter between the rectifier bridge and the 1st filter capacitor. 100% SS rectification allows the use of a large cap. in the 1st filter position. You can kill ripple freq. overtones such a large cap. generates ("hash") by inserting a LC section made of a high current RF choke and a 1000 pF. NPO ceramic or mica cap. between the large 1st filter cap. and the main filter choke. The RF component filter blackens the background nicely.
Eli D. |
#20 |
Eli, I like the sound of that last proposed PS. I'd like to move foward with that one. The rail voltage sounds good. The "Hash" filter sounds like a good option too!
| KT88 blocks? With E80CC + 6922 driver? | KaffiMann | Tubes / Valves | 10 | 8th October 2009 10:03 AM |
| PP KT88 Mono blocks? | TubeMack | Tubes / Valves | 38 | 11th June 2009 05:41 PM |
| "WTB" 300b Integrated or mono blocks | markmelheim | Swap Meet | 0 | 19th February 2009 12:20 AM |
| New Sensor's "Mullard" EL34 reissue? | Ty_Bower | Tubes / Valves | 0 | 16th May 2008 11:40 PM |
| 5-XLS's, 4-PR's, Adcom Mono Blocks and 1" MDF | DaHos | Subwoofers | 25 | 15th March 2005 01:25 AM |
| Page generated in 0.14923 seconds (81.38% PHP - 18.62% MySQL) with 11 queries |
