Old 2nd August 2012, 04:25 AM   #991
TubeMack's Avatar
Big favor please?
I'm extremely green when it comes to "point to point" wiring, and I'm having trouble laying out the HT supply. My last amp used a "Cap board" so I was cheating. MY issue with this amp layout is that I seem to want to lay it out just as it is drawn, which i'm sure is the wrong route to take. I just lack solid experience! I've never even really seen what one even looks like other than on a PC board Any chance some of you seasoned builders might be able to roughly sketch out the Supply out in a efficient, but easily doable layout? Something using a few turret, or terminal strips, or what ever?
Can anyone help me get going with this creative part. If I had a basic starting point, I think I could run with it, and alter to my specific needs with this chassis.....
EDit: I should have mentioned that I decided to use doubled caps in series with the associated balancing resisters to get the needed voltage rating
Old 2nd August 2012, 12:44 PM   #992
Can I suggest using paper cartoons. Cut out pcs of paper the size of components and then place them in a frame the size of your space. I did it with CAD as I was use to using it. Paper works just as well though.
Remeber to keep your iron at 90degrees to each other
FYI, I have a workable layout for the amp section when you ready.
Glad to see you working on it!
Living Life Doing the Waltz in 4/4 meter.
Old 3rd August 2012, 03:58 AM   #993
TubeMack's Avatar
As always, thanks SGregory, I'll give that a go, Doing all in my head isn't working well!
KT88 blocks? With E80CC + 6922 driver? KaffiMann Tubes / Valves 10 8th October 2009 10:03 AM
PP KT88 Mono blocks? TubeMack Tubes / Valves 38 11th June 2009 05:41 PM
"WTB" 300b Integrated or mono blocks markmelheim Swap Meet 0 19th February 2009 12:20 AM
New Sensor's "Mullard" EL34 reissue? Ty_Bower Tubes / Valves 0 16th May 2008 11:40 PM
5-XLS's, 4-PR's, Adcom Mono Blocks and 1" MDF DaHos Subwoofers 25 15th March 2005 01:25 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
