| diyAudio Sponsor | ||
I enjoy the EAR products, but they are a bit too spendy for me..
MC and MM preferred, need PCB Schematics, etc. tube of course.. |
#2 |
If you want to deal with LOMC carts., either step transformers or Allen Wright's hybrid cascode will be necessary. Even the quietest, high gm, triodes lack an adequate noise factor for μV. level signal work.
Eli D. |
#3 |
ok, scratch the MC requirement. I prefer MM anyway, for a number of reasons.
What out there is good, not too difficult? |
#4 |
ncdrawl
check out Hagerman Technology LLC: Cornet2 Vacuum Tube Moving Magnet Phonostage DIY Kit or http://glass-ware.stores.yahoo.net/aiphprkit.html just several phono preamps available out there |
#5 | |
Simmer down there, sport.
How does anyone really know? You might want to give This design a look-see. |
#6 |
What you want to do is one of the trickier things in valve/tube electronics. It took me several years to achieve a decent result, but you have a head start as you can buy Morgan Jones's book "Valve amplifiers" which has several designs and will be very helpful.
If you don't want to go down that route, you can find unstuffed pcbs from Hong Kong at reasonable prices which claim to be versions of famous commercial preamps. For instance, for $20-30 you can buy a "T Audio Phono Amplifier" which says it is based on the Matisse preamp. It only uses 2 valves/tubes (a 12AX7 and a 12AT7) but you will also have to source all the other components and build a separate 300V HT + heater voltage power supply. The circuit diagram/schematic also has to be downloaded so I should make sure about that before parting with any money. |
#7 | |
Previously: Kuei Yang Wang
I covered the design and some minor mods a few years ago at the Audio Asylum and following that a number of people also build their own. EAR 834P Copy Phono Preamplifier The text is in german, but the schematics are there. Of course, the same person also build one of my designs and actually liked that even better than the EAR copy: Simple Phono Preamp build #1 Simple Phono Preamp build #1 (Second link has a very nice buildup of this and links to threads here where the design originated) On the other hand Roman "Romy The Cat" Bessnov prefers the EAR 834P realised with Air or Vacuum capacitors for the equalisation. I would suggest not use a PCB, hard wired really does sound better. There are several Threads on building "my" Phono Stage design, including a wooly mammoth sized one about building and debugging the design by "Kofi Annan", worth seeking out. My posts are notable under the nom du guerre "Kuei Yang Wang". I also have a thread with a simple J-Fet Mc Pre-Pre. This comes highly recommended on bang4bucks and with the easily available 2SK389/LSK389 you can save yourself the hassle of selecting the Fet's for channel Matching Ciao T |
#8 |
A Simple Question deserves a Simple Answer....
#9 |
Thanks Sled!
I built a similar preamp about 25 years ago and was very pleased with it. It needed a rumble filter, but otherwise I could not have been happier. This should be a nice project for anyone.
Take the Speaker Voltage Test! |
#10 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Cary Audio Design SLP-30 with separate LPP-1 Phono stage | nelsondog | Swap Meet | 2 | 2nd November 2009 05:41 PM |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Audion sterling phono stage - a good base for future upgrades? | RobWells | Tubes / Valves | 9 | 8th April 2004 11:05 PM |
| Page generated in 0.11995 seconds (77.13% PHP - 22.87% MySQL) with 11 queries |
