SEPP design is it better then conventional PP - diyAudio
Old 26th May 2003, 01:32 PM   #1
Default SEPP design is it better then conventional PP
Hello everyone,
I was considering building something along the line of this SEPP design.
What do you think would be the advantage of this topology over conventional push pull, if any.
http://www.geocities.co.jp/MusicHall.../6AN5SEP2.html
Glass_painter
Old 26th May 2003, 02:14 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Default SEPP
Single Ended Push Pull (SEPP).
In SEPP the valves are lined up in series with respect to the DC standing current.
Signal input is to the lower valves which feeds an inverted signal to the grid of the upper one from its anode. The output is taken from the cathode of the upper valve (hence the low output impedance).
The net result is more power than for a straight single ended design, very low distortion, with a very low output impedance. This low output impedance is one of the keys to the amplifiers success - effectively 1/4 that of a classical push-pull arrangement as the valves are in parallel not series, with respect to output - and this allows the speakers to be driven effortlessly giving a crisp sound and good bass.
My own amps use this topology and I obviously like what it does.
Frank
Old 26th May 2003, 02:35 PM   #3
Brett's Avatar
Default Not neccessarily
Originally posted by Glass_painter
Hello everyone,
Glass_painter
I just want to say, try it and see for yourself. I have a much simpler design by another member here (moronix) I can email you if you'd like in a 20k PDF.
As to being better than PP, depends entirely upon which implementation, and how well each topology is optimised in an individual case.
If you'd like to understand more about the SRPP/SEPP amplifier, please take a look at the excellent article by John Broskie at Tubecad
Cheers
Old 26th May 2003, 06:49 PM   #4
Default SEPP
HI,
Thanks for the info everyone.
Frank, will you be able to post your SEPP designs or schematics here?
Glass_painter
Old 26th May 2003, 06:59 PM   #5
fdegrove's Avatar
Default SEPP.
It's an OTL design.
My design hasn't been published for the simple reason that I need to piece all the sketches together and put that into one readable diagram.
If you do a search here on OTL you will find a number of circuit diagrams by other people.
Or, you can once more take a look at the Tubecad site for the principles of operation.
Frank
Anyone out there try a SEPP OTL guitar amp?? aletheian Instruments and Amps 10 14th October 2005 03:05 AM
Sepp? Tim Wyatt Tubes / Valves 4 27th April 2005 06:34 AM
High efficiency (HORN) vs Conventional design mbon Multi-Way 13 8th June 2004 11:30 AM
SEPP design any exposure? Glass_painter Tubes / Valves 1 14th May 2003 11:45 AM
SEPP for philips 800 ohm loudspeaker Aiace Tubes / Valves 3 10th February 2003 07:20 PM
Copyright 1999-2017 diyAudio
