Tube-I-zator SRPP DAC I/V-Stage circuit discussions
Old 14th May 2012, 04:23 PM   #41
schubert is offline schubert  United States
schubert's Avatar
Default Tub-I-Zator in Sony CDP-710
I'd like to use one of these boards in a Sony CDP-710, but I'm having trouble figuring out how to implement it. I'd have to use the V-out version because the separation of the audio signal into right and left channels appears to occur after the DAC in analog by means of a MC74HC4053N chip (see attachment). Therein lies the problem - the MC74HC4053N signals are combined with the signal from the DAC (L+R presumably, since there's only one) after the op-amp, which I think is set up to invert the signals from the multiplexer. It looks to me like L-R and R-L signals are generated in the multiplexer, and the DAC mono signal is subtracted from them to get R & L. Can the SRPP circuit be used in this hodge-podge? If so how would it be connected and which tube would work? I'm rather new at this stuff and so far I just know enough to be dangerous. Any help would be appreciated.
Tube-I-zator SRPP DAC I/V-Stage circuit discussionsHide this!Advertise here!
Tube-I-zator Professional PCB dvb projekt Group Buys 967 29th August 2017 01:40 AM
Built the DDDAC MKII USB audio card, modified it to feed SRPP tube amp line stage wa2ise Tubes / Valves 0 8th June 2008 04:21 AM
srpp input stage nhuwar Tubes / Valves 11 31st July 2007 11:03 PM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 06:21 PM
CF and SRPP in one circuit . . rick57 Tubes / Valves 5 22nd May 2006 12:58 AM
